Go Back   Home > Forums > General Interest > Car Audio
Old 15th March 2010, 05:02 AM   #1
Default Kenwood 823
I repaired the power supply in this amp and outputs.
I have rail voltage on outputs and + - on the opamps on the main board i checked the switches and pots But still have no output on left channel.
Wondering where i start checking Left channel is dead
Old 15th March 2010, 05:21 AM   #2
Ok heres what i found on this amp.
If the low pass filter is on both channels produce output. If i turn the low pass filter off left channel is dead.
Bad switch??
Old 15th March 2010, 05:28 AM   #3
Check for signal on the switch. Drive signal into the good channel and see which pins have audio. Drive signal into the other channel. Do you have audio on the other row of pins?
This is probably best done with audio or a test signal that has more than one frequency.
Old 15th March 2010, 05:53 AM   #4
I cant find a signal on the switch for either channel.
Unless my scope is set wrong. I have it set on 2us 5v/div
Old 15th March 2010, 05:57 AM   #5
2mS, not uS. Try lowering the voltage to 1v. Disconnect the speakers and drive a strong signal into the amp. It will make it easier to see.
Old 15th March 2010, 06:05 AM   #6
Ok i did what u said and The pins on the switch are showing audio on 3 of the pins.(right channel)
Left channel no audio on any of the pins
If i switch it to lowpass filter i have audio on both left and right channel pins of the switch
Old 15th March 2010, 06:22 AM   #7
You need to confirm that the left channel signal is reaching the board. Check for signal on the biard just inside the RCA jacks.
Can you email me a photo at the best resolution possible?
babin_perry@yahoo.com
Old 15th March 2010, 07:03 AM   #8
Where do i test for audio?
Old 15th March 2010, 07:15 AM   #9
The first place would be on the back of the RCA jacks. Feed signal only into the dead channel input. Place the switch in stereo mode.
Old 15th March 2010, 07:28 AM   #10
Ok i have audio on the back of the rca jacks
kenwood ps500F damage Car Audio 2 23rd August 2008 05:02 PM
Kenwood thunder Chip Amps 3 20th February 2007 11:58 AM
kenwood 9102d mike49504 Car Audio 13 18th October 2006 01:14 PM
SEAS T17RE (823), need detail/review/opinion piro Multi-Way 29 4th October 2004 11:04 PM
PLEASE! Kenwood help! mjarve Solid State 1 23rd September 2004 04:04 AM
Page generated in 0.10190 seconds (74.00% PHP - 26.00% MySQL) with 11 queries
