I got this amp in and its dead. I tryed testing the voltages on the 494 all 16 pins read 0 volts.
I check the large diode behind the power and ground terminals and it measures good. Wondering where i should start checking? |
#2 |
Perry,
Wondering if you know where i should start checking to see why no voltage is getting to the 494 in this amp |
#3 |
Follw the traces back from pins 8, 11 and 12 to the next transistor on that trace. It should be a PNP transistor. What's the part number on it?
What is the DC voltage on it's 3 terminals?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
Ok its marked C945 and all 3 pins are at 0 volts.
#5 |
Follow it back further or look for other branches on the trace. It should be near the B+ terminal.
#6 |
I found the problem a blown trace.
Amp powers up and plays perfect. Thanks for your help Perry |
| Kenwood | thunder | Chip Amps | 3 | 20th February 2007 11:58 AM |
| kenwood amplifiers | MikeDE | Chip Amps | 1 | 11th February 2007 01:53 AM |
| kenwood 923 | mike49504 | Car Audio | 5 | 20th October 2006 12:13 PM |
| Which dac has this Kenwood? | tubee | Digital Source | 5 | 22nd August 2006 07:34 PM |
| PLEASE! Kenwood help! | mjarve | Solid State | 1 | 23rd September 2004 04:04 AM |
| Page generated in 0.07404 seconds (70.74% PHP - 29.26% MySQL) with 10 queries |
