#2 |
Thoose resistors run hot in this amp Its common.
Set your meter to ohms and measure across the resistors and post the results |
#3 |
#4 |
What i found with theese amps is thoose resistors you have pictured fail. Also the 2 switches usually get dirty and need to be cleaned. And sometimes you get problems with the driver boards for the outputs.
If i were you Id buy the amp. They are easy to work on and the parts arent very expensive. It might just be the resistor that is bad in it. |
#5 |
#6 |
How much is he asking for the amp the way it is?
#7 |
| I am curious? | tadiam | Solid State | 8 | 13th December 2007 01:18 PM |
| Curious | CARTRulz | Subwoofers | 3 | 13th June 2006 01:40 AM |
| Just a curious question... | needtubes | Subwoofers | 19 | 16th May 2006 01:53 AM |
| Curious | Madmike2 | Digital Source | 3 | 19th September 2005 08:48 PM |
| Page generated in 0.08431 seconds (78.58% PHP - 21.42% MySQL) with 10 queries |
