Go Back   Home > Forums > General Interest > Car Audio
Old 13th March 2010, 02:39 AM   #1
arazs5 is offline arazs5  United States
Default Kenwood kac - x521 major problem
i have a kenwood exceleron kac x521...it came out of one vehicle and sat in a cabinet for a while...when i re-installed it in another car the two 30A fuses blew a couple seconds after hooking everything up.i have a very basic knowledge of electronics, and i have a multimeter...where would the best place to start be?
Old 13th March 2010, 03:44 AM   #2
Souns like the power supply is blown in the amp.
First thing you should check is the power supply fets in the amp.
Set your meter to ohms and stick your red probe on leg 1 and stick your black probe to leg 3. Then leave you black probe on leg 3 and stick your red lead on leg 2 (middle leg). You should not red anything near 0 ohms.
Post your results on all of the power supply fets.
leg1 to leg3:
leg1 to leg 2:
leg2 to leg 3:
The image below is a diagram on how to check them
Basic Amplifier Repair - Transistor Test Applet Link
Old 13th March 2010, 03:55 AM   #3
Did it blow the fuse only after the remote voltage was applied (head unit turned on) or did it blow the fuse without remote voltage applied?
Old 13th March 2010, 04:32 AM   #4
blew them when remote voltage was applied
Old 13th March 2010, 04:59 AM   #5
That probably means that the output transistors are shorted. Q132-Q140 are the output transistors.
Old 13th March 2010, 05:13 AM   #6
i haven't tested anything yet, but say the output transistors are the source of my problem, is that something i could replace relatively cheap...where do i get components like that??
Old 13th March 2010, 06:09 AM   #7
The parts appear to be available but they're not cheap. Expect to pay ~$30 for the parts if nothing else has failed. PacParts, Kenwood Parts and MCM would be the distributors most likely to have the replacement outputs.
Old 16th March 2010, 02:54 AM   #8
here's some new insight to my potential problem...i opened up the amp got the board flipped around and found these burns...any insight???
Old 16th March 2010, 08:13 PM   #9
jol50 is offline jol50  United States
The transistors sometimes puke soot out the legs like that, will usually clean off. Get the numbers off them and look at MCM. I have the best luck there for those SK Sankens they often are. Those are the outputs. I found some at Littlediode also.
Old 16th March 2010, 08:53 PM   #10
Default might be a stupid question
i plan on using the amp bridged...is there some odd chance are there unused transistors that i could just "swap" for the burnt up one?? hard to find anyone selling just one skc3856...i was just curious before i bought a new one or 10 to make my minimum...or are there other components i should consider replacing while i'm in there??
Kenwood KAC-X810D mike49504 Car Audio 2 20th February 2010 01:49 PM
Kenwood KAC-X4R matdotcom2000 Car Audio 0 20th December 2007 02:36 PM
Kenwood KAC-X301T and KAC-X201T:Do they share the same board? spooney Car Audio 1 25th October 2007 01:08 AM
A problem with Kenwood KAC-846 bega_83 Car Audio 9 15th October 2007 12:19 PM
kenwood kac-715 purocolt Car Audio 5 4th September 2007 01:54 PM
Page generated in 0.10363 seconds (77.49% PHP - 22.51% MySQL) with 11 queries
