It's by motorola MTP75N05HD I think? I couldn't find this exact part all they gave me was data sheets. Is there a similar replacement?
Here's a link for the data sheet (it's not spam!) MTP75N05HD pdf, MTP75N05HD description, MTP75N05HD datasheets, MTP75N05HD view ::: ALLDATASHEET :::
Feel the PUNCH |
#2 |
If it's being used in the power supply of a Rockford amp, you can use the IRF3205 as a sub. If the gate resistors are greater than 51 ohms, replace them with 47 ohm resistors.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
I have a question? How much power can you expect from these type of amplifiers? Drivin at 4 ohms bridged. I heard around 690 watts?
Feel the PUNCH |
#4 |
Which resistor?
I wouldn't expect more than ~450 watts. If someone got 600+ watts out of it, they were probably trying to calculate the power output by measuring the voltage across a speaker load instead of a dummy load, which isn't accurate.
#5 |
It's a very small surface mount resistor. I think it's connected to the gate of the pwr supply fet. I also have a question? What if there is no gate resistor in place and you apply power to the amp? What is the operation result? Anything fry up?
Feel the PUNCH |
#6 |
If there is no gate resistor (gate not connected to anything), the FETs are likely to fail.
The gate resistor is a 68 ohm.
#7 |
I think that's what may have caused the new fets to fail funny how the fets with the missing gate resistor failed when I applied power to it including remote voltage. I really hope I can get it to work.
Feel the PUNCH |
#8 |
Replace the blown FETs and gate resistors. Before applying power, connect only remote and ground. Measure the DC voltage on the gate leg of each power supply FET and post the voltages you read.
#9 |
They were IRFZ44's that I put in that failed. I'll get the results in a bit.
Feel the PUNCH |
| Comparing Transistor Specs for swap | Zero Cool | Parts | 0 | 27th February 2010 12:05 AM |
| Need transistor with BD139 specs but higher wattage? | Dr. Popo | Parts | 10 | 22nd October 2009 06:34 PM |
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| Transistor specs. Help!...do you know those units? | destroyer X | Solid State | 9 | 11th September 2005 11:25 AM |
| 2SB1353 Transistor specs? | Chris Daly | Solid State | 8 | 27th September 2004 02:47 AM |
| Page generated in 0.10683 seconds (77.92% PHP - 22.08% MySQL) with 10 queries |
