Go Back   Home > Forums > General Interest > Car Audio
Old 11th March 2010, 08:08 PM   #1
CBR is offline CBR  United States
Default Orion 2150gx gain control problem
I have an Orion 2150gx that I purchased on ebay, and I'm rebuilding it. I noticed that the gain control can turn only 90 degrees, like its jammed or something. I’ve never had the amp running before and I worried that this may be the cause of the original problem. Should I spray some contact cleaner into it, or measure the resistance across the legs to check if it’s shorted?
Old 11th March 2010, 09:15 PM   #2
I would suggest that you not do anything to it. If it rotates freely through 90°, spraying something into it isn't likely to help. If you force it to rotate beyond the stopping point, you may damage something internally. It may work perfectly (other than not being able to rotate 270°).
If there is a significant mismatch between channels and you want to try to repair it, you can cut the heads off of the rivets and disassemble the pot to determine the problem.
Modifying a 2150GX into a HCCA250 mitchyz250f Car Audio 9 11th March 2008 12:51 PM
Negative Feedback Gain Control gni Solid State 22 3rd November 2007 11:14 AM
2150gx parts jbob30 Car Audio 12 4th October 2006 03:32 PM
Gain and volume control Hybrid fourdoor Chip Amps 17 24th September 2003 10:44 PM
Page generated in 0.05290 seconds (78.98% PHP - 21.02% MySQL) with 10 queries
