Go Back   Home > Forums > General Interest > Car Audio
Old 5th June 2011, 03:37 PM   #51
bega_83 is offline bega_83  Bosnia and Herzegovina
bega_83's Avatar
Send a message via Yahoo to bega_83
usually it is hot when motor stops spinnin em, sometimes its in mid of the song, sometimes when i press next track.
does the same on both audio and mp3 discs.
Old 5th June 2011, 06:37 PM   #52
bega_83's Avatar
ok, i recheck and retested it. with engine and amp off it works fine. when engine is runnin i have the prob. i suspect that vibrations of engine are causing it. :/
Plastic holders of HU are broken and i tighten it up with rubber implants.
Old 12th June 2011, 08:03 PM   #53
bega_83's Avatar
another newb question:
is it safe to put two 10" subs in parallel on bridge of kenwood kac-823 (yea, i got suckered again when it got shipped it wasnt 923...)???
if yes, is there certain level to which? if no, why?
i mean on Perry's website it says its not safe unless amp supports 2ohm load.
on this one there's a 4-2 ohm switch so its confusing me.
TIA
Questions about tweaking the Miniblok SET... 69CamaroSS396 Tubes / Valves 11 9th August 2008 08:37 PM
NEWBIE question SET vs. Solid State awhite1159 Tubes / Valves 42 21st September 2007 10:45 AM
Good SET for newbie Jimmy_The_Clown Tubes / Valves 3 5th November 2004 06:44 AM
SET kit for newbie Grahamt Tubes / Valves 9 7th June 2004 02:22 PM
Newbie wants to build first set of speakers tacomaboy Multi-Way 15 14th January 2004 02:36 AM
Page generated in 0.06903 seconds (71.28% PHP - 28.72% MySQL) with 11 queries
