Zapco Z400c4-SL no power supply
Old 11th March 2010, 07:00 AM   #11
fongman is offline fongman  United States
I have a fosgate 301s. Will that work?
Old 11th March 2010, 07:20 AM   #12
I have a Rockford fosgate 501s. Will this work?
Old 11th March 2010, 07:22 AM   #13
Perry Babin is offline Perry Babin  United States
It should. Try to remove it intact.
There are two rows of 4 FETs near the transformer. Find the two wires that connect to the center legs of the FETs. One will go to two of the outer primary windings. The other will go to the other two outer primary windings.
Find the wires that are directly connected to the non-bridging speaker terminals. These will go to the two center secondary wires.
Find the wires that are directly connected to the B+ terminal of the amp. These will go to the four center primary windings.
The remaining two wires should go to the rectifiers. Each of these will connect to one of the outer secondary windings.
Old 11th March 2010, 07:24 AM   #14
I'd use the 301 but the 501 should also work.
Old 11th March 2010, 07:47 AM   #15
Can I use a earthquake 200x?
Old 11th March 2010, 07:50 AM   #16
I don't have any information on the earthquake amp.
Old 11th March 2010, 08:08 AM   #17
I'm confuse on where they go? On the Zapco amp, there are p1-p8 where the transformer used to be. I have not taken the it out of the fosgate amp yet. I will post you a picture of what it looks like.
Old 11th March 2010, 08:33 AM   #18
Old 11th March 2010, 08:36 AM   #19
Old 11th March 2010, 08:38 AM   #20
You're going to have to use your multimeter to find what the various wires connect to in the zapco.
Zapco Z400c4-SL no power supplyHide this!Advertise here!
Solid state power suppy for CAT SL-1 pwan Tubes / Valves 0 7th January 2008 02:57 PM
Real power of zapco z600c2 Clipped Car Audio 5 13th September 2007 05:40 AM
Zapco z400c4-vx problem shallowfu Car Audio 17 4th November 2006 04:14 PM
Zapco Z400C4-SL scott-leanne Car Audio 23 13th May 2006 07:44 PM
Zapco SX-SL Processor.... ? coogj1 Car Audio 2 4th February 2005 02:22 AM
