diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Zapco Z400c4-SL no power supply (http://www.diyaudio.com/forums/car-audio/162955-zapco-z400c4-sl-power-supply.html)
fongman 11th March 2010 12:42 AM
Hi, guys. I just got this amp and was told that it was not working. I will try to fix it with everyone's help. I try powering it up and the fan is working and power light is on. I have no speacial plug that zapco used. So i'm not trying to get sound yet. But i open it up anyway. Big suprise to me, the power supply is missing. I'm stuck now. I need the schematic for this amp or where can i buy a new? I don't see anything burn or missing, only the power supply. Any help is thankfull.
http://i620.photobucket.com/albums/t...6/DSC02700.jpg
Perry Babin 11th March 2010 02:02 AM
You should try contacting Zapco to see if they can supply a replacement. It's unlikely that they will but you should try that before you try to make one.
Have you tested the outputs to see if any were shorted. It may not seem important at this point but if the amp has a lot of other damage, it may not be worth the effort/expense to repair.
fongman 11th March 2010 02:11 AM
I will test them tonight.
fongman 11th March 2010 03:35 AM
All the outputs are ok.
Perry Babin 11th March 2010 03:42 AM
What's the voltage rating on the rail caps?
fongman 11th March 2010 06:29 AM
Without the power supply will i get a good reading?
Perry Babin 11th March 2010 06:33 AM
Read the numbers off of the side of the caps.
fongman 11th March 2010 06:39 AM
The 4 larger ones on the left are 4700uf 50v and the 5 smaller ones on the right are 4700uf 16v.
Perry Babin 11th March 2010 06:49 AM
Do you have any amplifiers that you could 'borrow' a transformer from?
It doesn't need to be anything special. I think it would be good to drop a transformer in it so that you could determine the condition of the amp before you spend any money on a new transformer.
Robcrx 11th March 2010 06:59 AM
contact robert@zapco.com
he usually answers quickly !
Resources saved on this page: MySQL 18.75%
