#31 |
They are ok
#32 |
I've found out that p1 and p2 are ground. P3 and p4 are power. P5 and p8 are also ground. P6 and p7 are power. I will install the transformer and see what happened?
#33 |
There is a problem if all of the resistances to ground are accurate. I don't know any way that the wires that go to the FETs could read 10 ohms or less to ground and the FETs not be defective. Are you sure it was 10 ohms and not 10k or 10M ohms?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#34 |
What do you mean 'power'? Connected directly (0 ohms) to the B+ terminal of the amp?
#35 |
I was going to put p1 to p5, p2 to p8, p3 to p6, p4 to p7. Using the transformer.
#36 |
With the information that you've provided, I can't help any more than I have.
#37 |
I understand. I finally put the transformer in and got the amp to power up. The protection light is on and so is the cliping light. Zacpo don't really want to sell parts so if i want to fix it i will have to send it in. They are about 2 hours from me. I might evern put it up on ebay because i think some body can use it for parts? Thanks for your help.
| Solid state power suppy for CAT SL-1 | pwan | Tubes / Valves | 0 | 7th January 2008 02:57 PM |
| Real power of zapco z600c2 | Clipped | Car Audio | 5 | 13th September 2007 05:40 AM |
| Zapco z400c4-vx problem | shallowfu | Car Audio | 17 | 4th November 2006 04:14 PM |
| Zapco Z400C4-SL | scott-leanne | Car Audio | 23 | 13th May 2006 07:44 PM |
| Zapco SX-SL Processor.... ? | coogj1 | Car Audio | 2 | 4th February 2005 02:22 AM |
