I have an Alpine mrp-m450.
I removed it and reinstalled it in order to paint my speaker box. Upon hooking it back up, the power light came on for a few seconds and went off. I have tested the power, ground, and remote leads when disconnected from the amp. They are all operating properly. However,... when I connect them to the amp, the power lead drops to around 6-7 volts which leads to the amp not working. I have taken the amp apart and not noticed any burnt transistors. Anyone have any ideas? Thanks ahead of time. I will post more info and updates asap. -josh |
#2 |
The problem is in the wiring in the vehicle. If the amp was drawing enough current to drag the voltage to 6v, the fuse would have blown in the B+ line feeding the amp. I'm assuming that the vehicle's battery is in good condition and able to start the vehicle.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
I'll go further and wager its a ground issue... |
#4 |
The amps power wire is connected directly to the battery and has an inline fuse.
The ground is connected to the trunk metal via a bolt. The wiring was not changed as I only removed and reinstalled the amp. The amp worked fine before. ... I went out side to double check as I was typing this.... The amp is now turning on and voltage is fine. (strange because no change since last time i checked) But now.... there is absolutely no output (audio input is good). (May have accidentally touched wires in the past 2 days of testing) Still no sign of burnt transistors. The amp is open and connected. Any particulars I should check ? Any help greatly appreciated! |
#5 |
Double checked a second ago...
wiggled the ground. Amp is now turning on and voltages are correct. But now... there is NO output whatsoever (audio input is good). (May have touched/crossed wires in the past 2 days of tryin to figure this out) The amp is opened and connected. Still no sign of burnt transistors. Fuses are still all good. Any particulars I should check? Any help greatly appreciated. I am no stranger to soldering on pcbs and components. If only I could figure out which components need to be replace. |
#6 |
How did you confirm that the signal line feeding the amp had audio?
#7 |
Check your speaker leads, too.
Tim |
#8 |
[IMG]file:///C:/Users/JOSHSA%7E1/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/JOSHSA%7E1/AppData/Local/Temp/moz-screenshot-1.png[/IMG][IMG]file:///C:/Users/JOSHSA%7E1/AppData/Local/Temp/moz-screenshot-2.png[/IMG][IMG]file:///C:/Users/JOSHSA%7E1/AppData/Local/Temp/moz-screenshot-3.png[/IMG]none on the transistors are proving to be shorted
but some of my transistors (IRFZ44N) on the output side are reading >1 volt http://www.bcae1.com/images/gifs/trnchk04.gif is this normal? |
#9 |
is a voltage regulator essentially a transistor
#10 |
Many voltage regulators use transistors but not all.
Reading >1v? How was that measured?
| Steel Leads and Tinned Copper Leads | impsick | Parts | 0 | 19th April 2009 10:01 AM |
| 2 Remote Amp Leads into Deck ?? | metaverse | Car Audio | 9 | 8th February 2009 02:13 AM |
| Connected speaker wires from one amp into another... | buzzman | Solid State | 2 | 2nd January 2007 01:52 AM |
| Noise on speakers - RCA not connected to amp | feelinhipp | Car Audio | 13 | 8th June 2004 04:32 PM |
| P3A Amp hums when connected to XO | Patrat | Solid State | 7 | 15th July 2003 12:41 AM |
| Page generated in 0.10138 seconds (78.72% PHP - 21.28% MySQL) with 10 queries |
