Im working on a amp legacy and the power supply fets are blown.
They are using p60nf06 . Are theese the same as stp60n06?? Or whats a good replacement? |
#2 |
The STP60NF06 has a much lower input capacitance than the STP60N06. The NF is available from Future Electronics. If you want a sub, you could probably use the IRFZ48.
What is the value of the gate resistors?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
will 3205's or fqp65n06's work in this amp?
#4 |
What are they using to drive the FETs?
What value are the gate resistors?
#5 |
The drivers they are using are C1815 and A1015
Gate resistors are 100 ohm |
#6 |
If they're using an emitter follower pair as drivers you can use the 3205s if you reduce the value of the gate resistors to 47 ohms.
#7 |
Ok the outputs are also toasted in this amp they are using 2SA1943's
Will the @sa1987's or the 2Sc5359's work instead? |
#8 |
It appears that they're very similar. I'd expect them to work. Confirm that the idle current remains low when the amplifier is hot.
| mosfet question | mike49504 | Car Audio | 5 | 9th December 2009 07:13 AM |
| SMPS Mosfet Question | thefish | Power Supplies | 13 | 21st November 2006 08:41 AM |
| Mosfet Regulator Question | Rory Christ | Pass Labs | 0 | 28th March 2004 02:35 AM |
| Choice of MOSFET, and SoZ question | JFETglare | Pass Labs | 7 | 10th October 2003 09:19 PM |
| Mosfet Matching Question | vinay | Pass Labs | 1 | 20th October 2002 08:24 PM |
| Page generated in 0.07627 seconds (74.10% PHP - 25.90% MySQL) with 10 queries |
