I'm in the process of re-wiring my car from the head unit back to the amps... When I power up the car, my head unit and my two amps come on for a minuted, then cut right back off, and it repeats this for about 4 or 5 times, then they just go off and don't come back on. All of my grounds are solid. Both amps are getting power. Would this have anything to do with the remote wire? This was the problem I was having before I decided to re-run everything. I even bought a new amp and head unit to fix this. Please help me out!
#2 |
You need to confirm that the voltage to the amp and head unit are present when the amp/head unit cut off.
When measuring the voltage on the various power wires on the head unit, place the black probe on the case of the head unit. When measuring the voltage on the B+ and remote terminals of the amp, place the black probe on the ground terminal of the amplifier.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| LEAK stereo 70 cutting out | Minimuslover7 | Solid State | 10 | 24th August 2009 04:56 PM |
| My 66 Fender bassman tube guitar amp is cutting out intermittently and is making a bl | signalpaths | Tubes / Valves | 6 | 8th June 2008 04:21 PM |
| CAMBRIDGE A3i cutting in & out help! | Eggzy | Solid State | 19 | 18th June 2006 06:16 PM |
| T-Amp Channel Cutting Out | Diomedian | Class D | 16 | 15th February 2006 11:34 PM |
| Sonic impact t-amp cutting out after mods | markysoft | Class D | 1 | 10th November 2005 12:24 AM |
| Page generated in 0.06135 seconds (79.74% PHP - 20.26% MySQL) with 10 queries |
