Rockford Fosgate P10002
At the very least, you need to replace:
Q2021
Q2025
Q2028
R2081
R2092
R2099
Desolder R2081, R2092 R2099 and check:
R2094
R2097
R2074
Remove Q2028 from the circuit, reinstall R2081 and R2092, clamp the transistors to the heatsink, insert a 15 amp fuse in the B+ line and power up the amp. Does it still have DC on the defective channel's speaker terminals?
If not, does the defective channel produce clean audio?
Ok I just did as you asked and heres the results
R2094 - 10.0
R2097 - 39.0
R2074 - 10.0
Yes I do still have dc on the defective side after removing
the defective fet and resistor. It jumped around from neg to pos.
I'm going to test for audio now, but I have one quick question before I do. Are there l.e.d. lights on the board? Reason I'm asking is because I saw a red light flash and also a yellow light flash near were it says thermal on the board.
is anyone on this thread anymore? i need a bit of info. i have the same amp. my power mosfets are bad.top right corner of amp that is picturd on page 1. i can find 4 of the 6. the very last two i cant cross anywere. they are on the chip marked as CQ543 and CQ614. what can i put in there that will work? any guidence will be greatful. i really think these forems are educational to the fullest. THANKS GUYS!!!
