I got this amp in for repair.
When powering it up it draws excessive current. SO i unplugged the output board from the power supply board and amp idles fine. I checked the outputs all seem fine. Wondering where i need to check next. |
#2 |
Driver IC.
Tim |
#3 |
Ok had the modle wrong pq10.2
Which one is the driver ic? |
#4 |
Plus Tim is most likely remembering the PQ amps that I remember which used UPC1270AH or UPC1225 driver chips for each channels set of outputs. I recently did a channel repair on a Alpine using these and everywhere wanted $12.00 each for a $2.25 part. I am guessing due to their age and lessening availability. Glad i found my private NOS stock pile from yester-year... By chance have you ohmed the outputs yet, or does this amp use large STK modules. ADS did use these way back a very long time ago on their Power plate series as I recall. Plus I do recall some of these PQ amps being 12 volt powered and not using a switching power supply at all and these were all bridged discrete device channels as I recall also. Your asking a lot mike with out posting a snap or two of the inside to jog a old timers memory ![]() Give us a hint if you could of what it looks like please ? I have been in all of them but the I am drawing a blank with your model number duh ...thx...C
#5 |
Heres the pics as requested.
The IC'S in it are UPC1270H NJM5532SD C1237HA I tested the outputs on ohms setting all test good |
#6 |
Clamp the transistors to the heatsink, connect your meter to one of the emitter resistors and power up the amp. Find the emitter resistor that has more than ~0.000v DC across it. That will show you the channel that's passing too much current.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#7 |
I can post a schematic tomorrow PM for the PQ10.
Tim |
#8 |
Perry and Tim are correct Mike. The UPC1270 is your channel driver, and they fail and usually so does a output or two. Should not be too complicated for a tech like yourself ..thx for the pic, it all came home right away...
#9 |
Here's the schematic that was included with the PQ10's manual. From your pics, the PQ10.2 looks close enough.
Print quality was poor as supplied by A/D/S, I can barely make some of it out with reading glasses on the original.
Tim |
#10 |
THanks Perry,1moreamp,and Tsmith for the help ill order the parts and replace the defective ones.
I also found the UPC1270H for $2.24 each |
| ads 860mx | mike49504 | Car Audio | 8 | 8th October 2008 08:25 PM |
| ads 860mx | mike49504 | Car Audio | 1 | 5th September 2008 07:07 PM |
| Ads Pq10...p440...850mx | Clipped | Car Audio | 7 | 3rd March 2008 06:48 AM |
| ads pq20 | mike49504 | Car Audio | 3 | 8th August 2007 01:11 AM |
| What r these in ADS amp | variable | Car Audio | 5 | 27th June 2007 02:32 AM |
| Page generated in 0.09604 seconds (79.90% PHP - 20.10% MySQL) with 11 queries |
