Go Back   Home > Forums > General Interest > Car Audio
Old 24th February 2010, 01:09 AM   #1
Default ppi sedona 200 problems
I am getting power light without any remote hooked up!
The amp has been in my car for 5 years and I was getting something from the trunk and noticed that the power light was on without the car on.
One of my kids left a cup with pop in it setting on the rear deck and it spilled down behind the seat and into the amp through the gain control.
The amp works fine other than that.
I tryed to find where the remote ties into pwm but it goes to a couple different places.
I need to know what to look for that might be shorted.
Old 24th February 2010, 01:55 AM   #2
This is the turn on circuit for some of the ppi amps. Maybe it's close enough to yours to be of some help.
Old 25th February 2010, 12:16 AM   #3
My amp is like the older AM style, I am not having any luck finding where the remote goes.
The amp was built in 91 pretty much like a 2075m.
Old 25th February 2010, 12:32 AM   #4
On the older AM amp, it likely goes to an inline resistor network first. Can you post a high resolution photo of the inside of the amp?
Old 25th February 2010, 01:25 AM   #5
here are some, let me know if you need a different area on the board.
Old 25th February 2010, 01:29 AM   #6
There's a trace exiting from under the speaker/remote connector near the remote wire. Do you have ~0 ohms continuity from that trace to the blue wire?
If so, do you have ~0 ohms continuity from the blue wire to the black resistor network (black, 8 legs) just left of the power transformer?
Old 25th February 2010, 01:36 AM   #7
I have 2.458k ohms from remote wire to the trace.
Where on the resistor network would I probe at?
Old 25th February 2010, 01:50 AM   #8
The a06 and a56 transistors have the pop residue on them could one of them be shorted and cause this problem, they are tied into the resistor network?
Old 25th February 2010, 02:27 AM   #9
I'm relatively sure that the trace in the orange rectangle should be directly connected (~0 ohms) to the remote terminal. Is that the one you found 2+k ohms to the blue wire?
Check for continuity to the other traces there also.
That residue isn't likely to cause problems in that part of the circuit but you should remove it because it may cause corrosion which could cause the amp to fail.
You would probe the legs of the resistor network.
Old 25th February 2010, 07:50 PM   #10
I was checking the wrong trace, I have 0 ohms up to the sip resistor network.
PPI A600 problems Riveted1 Car Audio 5 29th January 2009 08:35 PM
PPI Sedona amp crossovers IrishboyM4 Car Audio 0 10th November 2008 05:04 AM
ppi pc450 problems jordan_ciaramit Car Audio 4 14th November 2006 03:07 AM
PPI Sedona 200iQX Schematics jgrimsley Car Audio 0 1st November 2006 03:30 AM
PPI amp problems... SimonB Car Audio 3 14th December 2004 09:13 PM
Page generated in 0.09448 seconds (81.58% PHP - 18.42% MySQL) with 11 queries
