Go Back   Home > Forums > General Interest > Car Audio
Old 22nd February 2010, 11:26 PM   #1
Default Kicker zx150.2
I got 2 of theese amps in for repair i believe they have the same problem.
Amp has no output.
I checked for rail voltage at outputs i have nothing .
I checked power supply fets with amp powered up black prob on chasis ground
Leg1:0
Leg2:13.92
Leg3:0
The reading are from the power supply fets IRF44's
wondering what to check at this point?
Old 22nd February 2010, 11:30 PM   #2
A photo of the inside of the amp would be helpful.
The voltage on the 494?
IC#
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Old 23rd February 2010, 12:06 AM   #3
Ok i repaired a few solder joints on the rectifiers and now on the outputs i have 27.89 On the middle leg of tip 35
On tip 36 i only have 2.24 on the middle leg
tl494
1:1.08
2:3.64
3:.06
4:0
5:1.51
6:3.42
7:0
8:12.32
9:5.16
10:5.16
11:12.32
12:13.89
13:5.03
14:5.03
15:5.03
16:4.32
Old 23rd February 2010, 12:21 AM   #4
Assuming that you used the secondary center tap as the reference, the lack of voltage could be caused by...
open rectifier
broken connection on rectifier
broken connection on jumper wire connecting the rectifier to the outputs
Old 23rd February 2010, 01:43 AM   #5
Ok i repair the issue with the rectifiers i now have both postive and negative rail voltages on outputs.
Still no output from either amp.
wondering where i go from here?
Old 23rd February 2010, 01:48 AM   #6
Is the preamp board connector labeled to show the left and right signal pins?
If so, see if there is audio at that point.
Have you run all pots and switches through their entire range?
Old 23rd February 2010, 02:15 AM   #7
On the connecter pins its labled R -15 SGND +15 L
Pin1:.01
pin2:-14.57
pin3:.04
pin4:14.65
pin5:.09
If that helps any
Old 23rd February 2010, 02:24 AM   #8
You'd have to drive the input with a strong signal and measure the AC voltage on the L and R pins.
Old 23rd February 2010, 02:36 AM   #9
i drove the inputs with 8 volts and measured the left and right pins
left pin:14.79 volts
right pin:14.33 volts
meter set on ac
Old 23rd February 2010, 02:43 AM   #10
Follow the traces from the L and R pins (on the main board). What is the first transistor it goes to? It likely goes through a resistor before going to the transistor.
Is one leg of that transistor connected to the secondary center-tap?
Kicker zx750.1 texasrebel1 Car Audio 2 10th January 2009 04:46 PM
I need help with a Kicker DX700 chipper Class D 5 8th January 2009 07:45 PM
kicker warhorse tadej Car Audio 10 17th August 2008 03:05 AM
Kicker Amps skooter Car Audio 3 8th November 2007 03:53 AM
Copyright ©1999-2013 diyAudio
