#11 |
Have you checked all of the driver transistors and the gate resistors for the outputs? Those commonly fail when the outputs fail.
Do you have an oscilloscope?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#12 | |
![]() I have messured alot off DC voltage around U8-9 D16-D17 it´s looking fine now. Output has zero DC and I can load the amplifier (100W@4ohm for now) BUT The Power led in the amp will still not light up Do you have any ideas for "protection voltage or ref voltage" for the protection circuit I can measure or am I still missing something here?? Best regards Kim |
#13 |
Does it produce rail voltage?
If not, post the DC voltage on the TL494 (594) power supply IC. IC# Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14: Pin 15: Pin 16:
#14 | |
I that what you mean? Kim |
#15 |
Yes.
When I get back in the shop tonight, I'll see if I can determine what's causing the amp to appear to be in protect mode.
#16 |
he also wanted voltage, compared to gnd, of every pin of TL, check schematic, I think you can see were led is connected to
#17 |
Do you have the schematic diagram?
#18 |
I do, most of it anyway, need it?
#19 |
#20 | |
allright But not the power led I will measure TL 494 for you all 16 pins
| Advice needed Technics Sl-15 cover removal | musicmantech | Analogue Source | 2 | 31st July 2009 03:05 PM |
| technics SL-PS900 pics inside needed | mat_one | Digital Source | 0 | 5th August 2007 08:39 PM |
| Technics SL-5 | pinkmouse | Analogue Source | 22 | 5th July 2006 10:59 AM |
| technics sl-1600 | kazoo | Analogue Source | 2 | 11th August 2005 01:10 PM |
| So/Sl ratio? | Tomac | Multi-Way | 3 | 14th January 2004 11:48 PM |
| Page generated in 0.13413 seconds (65.34% PHP - 34.66% MySQL) with 11 queries |
