Go Back   Home > Forums > General Interest > Car Audio
Old 20th February 2010, 12:38 PM   #1
Default Output oscillation in car but not on bench.
I recently fixed a Dragster 5 channel amp, with the help of Perry here on the forum.
It tests fine on the bench, but when I installed it into a car, the outputs oscillate like crazy. Its not engine noise, as it happens with or without the engine running.
If I directly connect an MP3 player to the amp via a short RCA cable, it plays fine through every channel.
I thought maybe the head unit is faulty (i've never used the RCA outputs on this one yet), so I swapped that for another and the problem is still there. I swapped the RCA cable from the head unit to the amp, and the problem still occurs - even with the cable running outside of the car to the trunk away from any other wires.
I even tried a different 6 channel amp, and thats working fine with the original head unit and wiring.
Any ideas?
Old 20th February 2010, 07:44 PM   #2
You need to confirm that the RCA shield ground is intact.
RCA Shield Repair
Also measure the DC voltage on the shields of the amplifier's RCA jacks.
Old 20th February 2010, 08:05 PM   #3
Ive had this same problem, but with an amp made from scratch im certain it has something to do with a ground loop
Old 21st February 2010, 06:19 AM   #4
ppia600 is offline ppia600  United States
Does it only oscillate with the car running? If so, Perry and chris have it right. It could be the deck or the amp causing the issue. Even though you tried another amp, some amps will be less susceptible to ground shield issues.
Don't worry... you can always turn the gain down!
Old 21st February 2010, 05:52 PM   #5
Yeah, I thought first it could be a ground loop. I grounded the head unit directly to the body, and made sure the amp had a real nice short ground, but still no change.
The oscillation occurs with or without the engine running, and it seems to happen only when a quiet signal is inputted.
I did have a good brainstorming last night, and I thought the same as Perry... maybe the RCA shield is no longer intact on the amp. I'll take a look at this in the next day or so and report my findings.
Old 22nd February 2010, 11:18 AM   #6
Ok,
So I checked out the guide on Perry's website regarding the ground shield on headunits.... are they tested in the same way on amplifiers?
I have infinate resistance between the rca shields and the amps ground terminal, so it looks like that's my problem.
Old 22nd February 2010, 01:06 PM   #7
Amplifiers are different. For budget amplifiers, the RCA shield is generally connected to the non-bridging speaker terminals.
For amplifiers with balanced inputs or amps using some form of noise canceling circuit, it's more difficult to test the input circuit.
Old 26th February 2010, 09:36 PM   #8
I remember measuring the rca out on the head unit it was open, but at the time didnt know if that was right. i know now thanks perry
Looking For Output Transistors For Vintage Car Radio 65blkbkgt Car Audio 14 29th May 2010 01:58 PM
Car amplifier output transformer rem280 Solid State 1 11th November 2009 10:23 AM
Can oscillation destroy output transistors? JojoD818 Solid State 10 13th June 2003 12:32 AM
Increasing Power Output of a Car amplifier Dj BASS AMP Solid State 5 5th October 2002 11:37 PM
Page generated in 0.10045 seconds (75.52% PHP - 24.48% MySQL) with 10 queries
