Go Back   Home > Forums > General Interest > Car Audio
Old 19th February 2010, 02:40 AM   #1
Default Thunder 6500D
Got a thunder 6500D I repaired it awhile back with new outputs, and it worked fine.
Guy drove it hard, blew the subs, and in turn blew the outputs up again in the amp.
Took the amp apart, replaced all 4 outputs and replaced both gate resistors. they were ok, but i changed them anyway. I used 52N20s in place of the 45N20s because i had no more 45N20s.
So after powering up, if the amp is REALLY low volume, low enough so you can still hear it, but only if the room is somewhat quiet. it sounds fine. soon as you turn it up, it starts to distort, pop, and crackle quite alot. the harder you push the amp, the worse it gets, and the SMPS inside the amp starts emitting noise as it goes. Plus when the bass hits, it pushes the subs inward when driven kinda hard. so something not right.
I pulled the drivers and the small SOT23 transistors and checked them out of circuit for opens, shorts, and leakages that shouldnt be. everything is ok. so i put it all back in.
Also the LM311 is getting kinda hot, so i replaced it anyway, still gets hot. the 2 SMD higher wattage resistors next to the LM311 get very hot. also 1 set of drivers get kinda warm as well, while the other driver set remains cool. the 18v and -18v regulated voltages appear to be present. i have both positive and negative 60V rails.
I am at a loss on this one. any ideas?
Old 19th February 2010, 02:53 AM   #2
These self oscillating amps are VERY sensitive to the outputs that you use. The ones you installed may not be compatible. Do you have any IRF3415s?
Old 19th February 2010, 03:03 AM   #3
nope. none. just IRF3205s? I have IRF640s as well? and some IRF9640s? the 52N20 is a 45N20 with more current capability, i thought anyway...
Old 19th February 2010, 03:09 AM   #4
It's not the current rating that makes a difference. The only parts that I've found that work in these amps are the originals (but not all of the originals) or the 3415s. Others may work but I haven't had any luck finding any.
The 3205s can't withstand the voltage. The 640s can't handle enough current.
Old 19th February 2010, 03:19 AM   #5
i used 42N20s in here before. they worked. but i only have 1 of those left, and i need 4. so i guess its off to digikey.
Old 19th February 2010, 03:27 AM   #6
They may not have been working perfectly. The amp may seem to work perfectly but they might be borderline. Looking back at my notes, I tried the IRFB42N20Ds and they didn't work.
Old 19th February 2010, 03:30 AM   #7
well add the 52N20s hehe.
Old 19th February 2010, 03:34 PM   #8
digikey doenst have the 3415s.
Old 19th February 2010, 04:21 PM   #9
IRF3415 - Octopart
Mtx 6500d mike49504 Car Audio 17 17th January 2010 07:45 AM
MTX 6500D with problems copekyle Class D 0 17th September 2009 05:36 PM
MTX 6500D Repair Rasputin713 Car Audio 1 2nd September 2009 04:26 AM
MTX Thunder 6500D burnt ifrythings Car Audio 10 18th April 2008 05:35 AM
MTX Thunder 6500D does not power up tidom78 Car Audio 5 11th November 2006 06:36 PM
Page generated in 0.10293 seconds (76.85% PHP - 23.15% MySQL) with 10 queries
