Adcom GFA4402 - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 11th November 2010, 03:47 AM   #11
EnvisionAudio's Avatar
Hello, I ran across this post while searching for something else.
It's possible that a feedback optocoupler's CTR has drifted out of spec, pushing the PWM into a high duty cycle as the input voltage is turned up. Rare, but it happens. I think the Adcom has two.
DCX2496/DEQ2496 Car Audio Conversions
www.envisionelec.net
Old 11th November 2010, 12:40 PM   #12
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
thanks.
I'll take the amp off the shelves, dust it and check the rails. this has been sitting here for quite a while now.
Old 17th August 2011, 03:10 PM   #13
upping the thread. still looking for the schematics
Old 7th May 2013, 04:59 PM   #14
Sorry for bumping this. Does anyone know the rail voltages for this and the 4404 are ? I'm curious what power you can expect these to produce real world.
Old 7th May 2013, 05:00 PM   #15
Also, i have the service manual for both.
Old 10th May 2013, 03:03 PM   #16
can you please send me a copy of the service manual? I still have this in my possession so I could work on it once I find the time.
Thanks in advance!
Old 11th May 2013, 11:24 PM   #17
Here you go.
Old 12th May 2013, 04:42 PM   #18
Thanks! Had a look in the schematic and figured out what to check for the OVP problem.
It turns out the problem was a leaky 15V 1W zener D305 which should trigger an SCR during an overvoltage condition. I have no idea why they had to use a 1W part where a 0.5W part should work just fine. Going to replace it tomorrow and see how it goes.
I feel stupid now lol this amp has been with me for 4 years hahaha Lack of time and motivation (as this is just a favor for a collector friend) could have been the cause of taking this long.
The rail voltages for the main power stage are listed as +/-24V on the SM but I can check the actual voltages tomorrow if you like.
Old 12th May 2013, 05:35 PM   #19
That would be great! I'm wondering about the output from 2-8ohms stereo. Thanks!
Old 13th May 2013, 05:59 AM   #20
I measured the unregulated rails and saw about +/-22V with 13.2V input at the battery terminals.
I also realized there was an error with the PCB. The 9V regulator and bypass caps (red circle in attached pic) are not connected to the main ground which caused the regulated +/-34V rails to go as high as 45V with high battery voltage. I couldn't find any burnt trace and there aren't any signs that this has been repaired except for a few bodges on the fan circuit which seems to be from factory. A simple wire jumper fixed the problem.
I also replaced the leaky zener with the same 1W part (1N4744) because that's all I had in stock. Now the OVP trips at about 16V whereas it tripped at ~13V with the leaky diode.
adcom GFP565 Andy28 Parts 16 8th September 2012 01:32 AM
adcom gfa545 jeffreyd426 Pass Labs 4 26th January 2010 08:22 AM
Adcom display out damage Solid State 0 15th June 2008 02:52 AM
Possible Replacement for My Adcom Fearlessleader1 Everything Else 3 21st April 2007 11:13 PM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 09:09 PM
Copyright 1999-2017 diyAudio
