Go Back   Home > Forums > General Interest > Car Audio
Old 14th February 2010, 02:04 AM   #1
Default No start up Punch 160a4
This amp won't start up. I can apply remote voltage and no LED and draws very little current. The VREF pin of the 494 reads 4.84Vdc. Without rail voltage I have no +- supply either.
If the 339 senses a fault does that affect the 494?
Old 14th February 2010, 02:15 AM   #2
The 339 can shut down the amp.
Post the DC voltages on those two ICs.
494
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
339
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Old 14th February 2010, 02:24 AM   #3
494
Pin 1: 0
Pin 2: 4.414
Pin 3: .055
Pin 4: 4.8
Pin 5: 1.46
Pin 6: 3.22
Pin 7: 0
Pin 8: 14.8
Pin 9: 0
Pin 10: 0
Pin 11: 14.8
Pin 12: 13.48
Pin 13: 4.85
Pin 14: 4.85
Pin 15: 4.85
Pin 16: 0
339
Pin 1: 0
Pin 2: .7
Pin 3: 14.7
Pin 4: .314
Pin 5: 2.397
Pin 6: 4.85
Pin 7: .457
Pin 8: 4.85
Pin 9: 4.85
Pin 10: 4.85
Pin 11: 9.16
Pin 12: 0
Pin 13: 0
Pin 14: 0
Old 14th February 2010, 02:28 AM   #4
Looking at the numbers it seems Vref needs to be higher. Could I just lift pin 14 and see if the 494 would start?
I lifted pin 14, it will try to start and blow the 5 amp fuse in B+ line.
cory
Old 14th February 2010, 02:45 AM   #5
Are you sure that pin 8 of the 339 is correct?
Does pin 7 of the 339 go to the positive terminal of a 10uf capacitor?
Old 14th February 2010, 02:49 AM   #6
You can't lift pin 14 unless you lift both 13 and 14 and tie them together. If pin 13 isn't driven high, it causes the outputs on pins 9 and 10 to go high and the amp essentially tries to drag the positive 12v supply output to ground.
Old 14th February 2010, 03:00 AM   #7
Pin 8 reads 4.85V, pin 7 ties to the + side of C5.
I lifted pin 14 of the 339, not the 494. I should have stated 339 in my post.
Old 14th February 2010, 03:05 AM   #8
Is pin 8 of the 339 shorted to pin 9?
Can you lift pin 8 and connect it to ground?
Did you check the outputs?
Did you try setting the bias pots to the fully counter-clockwise position?
Old 14th February 2010, 03:24 AM   #9
Not shorted.
Tied pin 8 to gnd, same outcome as lifting pin 14 of 339.
One channel of outputs were shorted those have been replaced. The other side measures ok.
Old 14th February 2010, 03:34 AM   #10
I think this is the over-voltage shutdown. 14.7 shouldn't be too much but you could try setting it lower to see what happens. Reconnect pin 8 to the board as it was.
If the amp tries to power up with lower voltage but draws excessive current, remove the power supply driver transistors marked 1A (or 1G).
punch 100dsm help ben04srt Car Audio 12 1st February 2009 04:29 PM
Punch 45 - Weird Problem with Start-up bigphil Car Audio 5 30th December 2008 07:59 AM
Will start my new Gainclone from Start, Need Help samsagaz Chip Amps 4 27th May 2008 09:39 AM
Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY ppia600 Swap Meet 0 23rd February 2008 01:17 AM
My experience: the cheap punch set VS Greenlee punch vax9000 Tubes / Valves 5 21st July 2006 07:52 PM
Page generated in 0.08966 seconds (80.71% PHP - 19.29% MySQL) with 10 queries
