Go Back   Home > Forums > General Interest > Car Audio
Old 10th February 2010, 03:29 AM   #1
Default kicker 1500.1
Im rebuilding the power supply in this amp. All fets were toasted most of the gate resistors were bad and the driver also are bad.
Wondering if there is a good sub for the drivers B647 and D667 ?
Old 10th February 2010, 03:38 AM   #2
ok nevernind i found the originals
Old 12th February 2010, 06:19 PM   #3
I replaced all fets(3205's) in this amp replaced the gate resistors (100 ohm)
replaced the drivers (B647 and D667) and a couple 10k resistors next to the gate resistors.
When powering it up through a 1ohm 10 watt current limiting resistor it still draws 15 amps of current and the fets get red hot with 1 to 2 sec's
I pulled the rca jack board and the other driver board in it still draws current and fets get red hot.
Wondering where i go from here?
Old 12th February 2010, 06:30 PM   #4
Did you try pulling the rectifiers?
Are any outputs shorted?
Old 12th February 2010, 07:17 PM   #5
Do you know what they are using for rectifiers in this?? Outputs are out of the amp and it still draws current.
Not sure what the rectifiers are in this amp The F30D40D?
Old 12th February 2010, 07:38 PM   #6
Yes. Those are the rectifiers.
Old 12th February 2010, 07:58 PM   #7
Ok pulled the rectifiers in the amp now it powers up and idles perfect. So something in the output section. Wondering where i start checking
Old 12th February 2010, 08:11 PM   #8
Discharge the rail caps and measure the resistance across them. Do any read anything near 0 ohms?
Are any of the rectifiers shorted or leaking?
Old 12th February 2010, 08:13 PM   #9
How do i discharge the rail caps?
Old 12th February 2010, 08:16 PM   #10
Short the terminals of each capacitor (preferably through a dummy load or other resistor).
Massive p-1500.1 mike49504 Car Audio 27 7th April 2010 09:16 AM
Kicker ZX 1500.1 Smoked general_neo Car Audio 10 26th July 2009 10:38 PM
1500 Watt netuddki Solid State 22 3rd June 2009 09:50 PM
velodyne f 1500 help daran Subwoofers 0 30th December 2007 10:53 AM
Page generated in 0.09576 seconds (77.89% PHP - 22.11% MySQL) with 11 queries
