Go Back   Home > Forums > General Interest > Car Audio
Old 8th February 2010, 07:49 PM   #1
amc32 is offline amc32  United States
Default Ppi a1200
I am having a problem w/ a ppi a1200 amp. It looks like I have a complimentary power supply, where the fet's are working in pairs. The problem I am having is that when I install the fet's on one side of the power supply, the amp starts drawing 20 amps for a second or two then drops down to 1.5 amps. Then the fet's start to get blazing hot after just a few seconds w/o any load on them. If they are not in the other bank idles just fine w/o getting hot at all. Help would be appreciated in figuring out what is causing this problem. Thanks in advance.
...............I Hear in color.................
Old 8th February 2010, 08:31 PM   #2
This is an H-bridge supply. If the transistors are only in one side, the transformer isn't being driven. If no FETs overheat when all FETs are one side OR in the other side, the drive circuit is probably OK.
Is it possible that your 12v power supply voltage is dropping significantly when the amp is only drawing 1.5 amps?
You could have a shorted transformer, inductor or something in the audio section that's causing excessive current draw.
Profile A1200 XL Odd Power Supply amc32 Car Audio 5 26th November 2008 11:44 PM
PPI ART Series a404 "v" PPI Powerclass pc450 swap chemhaz Car Audio 2 21st November 2008 03:23 PM
Ppi A600 npenson Car Audio 4 27th August 2008 11:36 PM
Ppi Pc4100? dangus Car Audio 5 12th April 2008 07:44 AM
PPI vs. Alpine smokeaway Solid State 2 28th August 2005 11:51 AM
Page generated in 0.07028 seconds (77.98% PHP - 22.02% MySQL) with 10 queries
