Go Back   Home > Forums > General Interest > Car Audio
Old 7th February 2010, 05:02 AM   #1
Default Rockford Fosgate 600.5
I just got this amp in tonight for repair.oes anyone have a schematic for this or know the order the outputs go in it? Someone worked on it before and have power supply fets in the output section. Also the fets that are in this amp now are irf1010e's not sure if they are original or not.
And in the output section they have 540's 9540's irf9z34's and irf1010e's and i know thats not correct at all correct me if im wrong. But a 9540 and a 1010e working together?
Any help would greatly be appericated
Old 7th February 2010, 06:51 AM   #2
Yeah they have that in the bass channel sort of like a staggered output stage. RF has the schematic posted on their web site last I looked. It threw me the first time i saw it also. Plus if this is the defective channel be prepared to tweezers out some of the SMD transistor components sitting behind the outputs. I have never seen one of the just blow the outputs only, they always take down the drivers stages and several resistors also along the way....Have fun....
Old 7th February 2010, 07:32 AM   #3
Thanks 1moreamp,
Yeah it took out the 2a's the emitter resistors, the 10 ohm surface mount resistors, all the power supply fets, the gray and black diode , one of the 1n4003 diodes. Some of the 540's and 9540's in a couple channels.
Thats what i found so far wrong with it in 25 mins could be more then that.
But the guy is willing to pay for it i told him it would probably be an expensive repair
Old 7th February 2010, 11:22 AM   #4
If it's the same as a 600a5, the sub channel is class G so only 2 of the outputs are for audio. The other two are for rail switching.
Old 7th February 2010, 12:33 PM   #5
the sub channel has IRF9Z34,IRF5210,IRF540, and IRF1010E .
The other channels are 540's and 9540's .
Which the sub channel and 2 of the other channels have shorted outputs.
The power supply is using IRF1010E's Is this a good fet to use or should i switch to something else since this guy likes to abuse his equiment
Old 7th February 2010, 12:53 PM   #6
The 1010 is a good FET.
If this guy is abusive, tell him to use a fan to keep the amp cooler. If he doesn't run it below its lowest rated ohm load and he uses a fan, it should be reliable.
Old 7th February 2010, 01:32 PM   #7
Well ill post when i get the parts orderd and put in and let you know how the amp is. If its working or not
Old 5th March 2010, 02:58 AM   #8
i put new fets and outputs in this amp.
The other thing is i forgot to order the diode for it.
The diode is marked 28-150 its gray with a black stripe.
Wondering can i use a cross for this diode??
Old 5th March 2010, 03:16 AM   #9
That's a BYV28-150 and is difficult to match (for durability) with anything of a comparable size. If you're not going to use an exact replacement, I'd suggest using something like an MUR820 bent similar to the one in the following image. The left leg in the photo would be the same as the striped end of the original diode. If you use this as a replacement and the tab has to be cut off (for clearance), do so before you install it.
Old 5th March 2010, 04:13 AM   #10
well i had to order the original part. I order 10 of them from newark since i didnt have either one in stock. Plus wanna try to keep it original since its a customers amp
rockford fosgate 800a2 mike49504 Car Audio 11 4th February 2010 09:34 PM
rockford fosgate p4004 mike49504 Car Audio 3 7th December 2009 10:30 PM
Rockford Fosgate/Mosfet steven123654 Car Audio 5 2nd September 2009 03:13 AM
rockford fosgate transistors mike49504 Car Audio 2 20th January 2007 04:26 AM
rockford fosgate // alpine mike49504 Car Audio 1 25th December 2006 10:36 AM
Page generated in 0.26828 seconds (32.28% PHP - 67.72% MySQL) with 11 queries
