Go Back   Home > Forums > General Interest > Car Audio
Old 20th March 2010, 02:43 PM   #61
20v/div and 2mS/div.
I don't think the 540Ns are causing the problems you're having at this point.
Old 20th March 2010, 03:22 PM   #62
No voltage on the second set and no square wave on the sec set of rectifiers
Old 20th March 2010, 03:23 PM   #63
Can you post a photo of the windings on the transformer (where they go into the board)?
Old 20th March 2010, 04:02 PM   #64
Heres the pics of the windings
Old 20th March 2010, 04:03 PM   #65
heres another one also
Old 20th March 2010, 04:36 PM   #66
Did you see the square wave and DC with the scope on the first set of rectifiers?
Old 20th March 2010, 05:15 PM   #67
No gate wave on the first set either. Only place i have a gate wave is on the power supply fets
Old 20th March 2010, 05:23 PM   #68
With your multimeter, confirm that you have ~2.3v DC on pins 1 and 2 of the 494. Also confirm that you have rail voltage on the first set of rectifiers.
If you have those, the peak to peak voltage on the rectifiers may be too much for the settings you used on the scope. Set it to the highest v/div and make sure that you have the probe set to 10x (if it has a switch). If you see horizontal lines above and below the reference line, turn the vertical amplifier to whatever it takes to get those vertical lines to ~±3 vertical divisions. Then turn the timebase until you have ~3-4 cycles on the display. This basic procedure is something you'll have to do on may repairs so try to remember it.
Old 20th March 2010, 05:32 PM   #69
I think i have bad rectifiers in this amp i started testing like u said and now i only have voltage on 1 rectifier from the first set and voltage on 1 of the other set im gonna change them out and retest
rockford fosgate 800a2 mike49504 Car Audio 11 4th February 2010 08:34 PM
rockford fosgate p4004 mike49504 Car Audio 3 7th December 2009 09:30 PM
Rockford Fosgate/Mosfet steven123654 Car Audio 5 2nd September 2009 02:13 AM
rockford fosgate transistors mike49504 Car Audio 2 20th January 2007 03:26 AM
rockford fosgate // alpine mike49504 Car Audio 1 25th December 2006 09:36 AM
Page generated in 0.10238 seconds (78.16% PHP - 21.84% MySQL) with 11 queries
