Go Back   Home > Forums > General Interest > Car Audio
Old 5th February 2010, 09:40 PM   #1
Default Amp Powering Question
Hello all. As mentioned in my Intro, I am fairly a rookie when dealing with car audio. Simple installs I can complete. I have what may seem to be a silly question, but here goes.
Does an amp require a certain amout of power to push a sub? I ask this because I recently installed a alpine mrp-m500 in my car and I am not able to get any sound from the speakers. However, the amp is powering up. I know that the audio line feeding the amp work because I just connected to a speaker just to be sure and that worked as well. I have tried all I can think of to get this thing working so I am resorting to asking questions such as the one above. Very confused at the moment and hope someone can just turn on the light bulb for me. I hope I stated that clear enough, feels like I am talking in circles. Thanks in advance.
Old 5th February 2010, 10:15 PM   #2
Banned
OK put a voltmeter on the power line where it goe into the amp. Between the +ve and -ve, or ground (chassis unless it's a very old car). Put a signal into the amp. Look and see if the voltage is holding up at the input to the amp or if it is collapsing.
w
Old 5th February 2010, 10:27 PM   #3
It is holding up from what I can tell.
Old 6th February 2010, 12:42 AM   #4
Ok, so I retract my recent response. I must have been doing something wrong. Prior to me even powering up the amp, i noticed that I am getting like a 5 am reading on the power from the battery. When powered up, it stays around that and the remote is reading 12v. could this be a problem?
Old 6th February 2010, 05:54 AM   #5
Check all connections and also check the fuses if there is an inline fuse from the battery check it it could possibly be bad
Old 7th February 2010, 02:27 AM   #6
OK, so, I feel like a real dummy now. I got her working again. It appears the wire at the in-line fuse was loose and was not maintaining the power across it. While I feel bad, I must say I learned a lot in this process. Thanks to all of you for trying to help me out. I really do appreciate it.
Old 8th February 2010, 11:41 PM   #7
Last update on this. Looks like the original amp is working fine as well. the lack of power was keeping it in" protect-mode". Thanks to all for entertaining my newness to this stuff. I am looking forward to learning more as I continue to visit the site.
Battery-Powering a Trent TA-10 & a Citypulse DA2.03e leto Power Supplies 7 5th September 2008 11:15 PM
Powering up/down Amp ptah Solid State 14 27th February 2008 07:54 PM
Humming Speaker Protection relay when powering up (newbie question) slowpoke-nl Solid State 4 21st November 2007 02:32 PM
Question Regarding Powering a HU at Home kinser Car Audio 2 20th May 2007 05:16 AM
Powering an amp from just + and -? CryingDragon Solid State 11 22nd November 2002 10:04 PM
Page generated in 0.09215 seconds (76.26% PHP - 23.74% MySQL) with 10 queries
