Go Back   Home > Forums > General Interest > Car Audio
Old 5th February 2010, 05:40 PM   #1
Default orion cobolt 2105
I dont understand this amp.
I pulled all the outputs out of it and changed the drivers in it. Upon trying to power it up it draws excessive current. Even with the outputs out of the amp its reading shorted on the output pads between legs 1 and 3. Wondering what i should check next??
I also checked the diodes they are testing fine also
Old 5th February 2010, 05:45 PM   #2
Do you read a short or simply a low resistance?
Does it pull excessive current if you remove the rectifiers?
Old 5th February 2010, 06:14 PM   #3
if i pull the tip 31 and 32 c's it doesnt draw current then. But it still shows legs 1 to 3 on the outputs shorted not low resistance but shorted
Old 5th February 2010, 07:54 PM   #4
I've never seen one of these. I have no clue what those transistors are being used for. If you can't find the fault and need more help, post some photos of the inside of the amp.
MC 2105 Output stage grant_MH Solid State 16 22nd April 2009 10:58 PM
Orion #5 Clipped Car Audio 1 21st November 2008 04:34 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
JBL LE5 (2105) 5" Midranges... Guiness Swap Meet 0 16th March 2004 07:01 PM
The Orion is available diypole Multi-Way 0 2nd October 2002 03:05 PM
Page generated in 0.07470 seconds (69.78% PHP - 30.22% MySQL) with 10 queries
