Go Back   Home > Forums > General Interest > Car Audio
Old 17th March 2010, 04:00 PM   #11
Is it physically damaged or does it simply need cleaning?
Old 17th March 2010, 05:21 PM   #12
Red face yes pot says b20k on it
yes thats the one i need. theres got to be another vendor that sells them for a couple dollars.
Old 17th March 2010, 05:23 PM   #13
its physically damaged. it was bent and i tried to bend it back and broke it. I believe it was bound up and not adjusting the gain in the first place.
Old 17th March 2010, 10:07 PM   #14
If/when you remove it, apply additional solder to all legs of the pot. Lay the tip of your iron across 3 legs at once. When the solder is molten on all 3 legs, pull that half of the pot out. This only works if one of the circuit boards on the pot is broken (which yours is). It will keep you from pulling the vias out of the board.
Old 17th March 2010, 11:19 PM   #15
You can use a non conductive electrical wash spray to clean that pot and it should work like new.
Old 18th March 2010, 12:07 AM   #16
In the pic to the left you will see the exact used old style pot Autotek once used in their amps < Actually ZED >. To my knowledge Autotek never had any engineers or build shop areas, just a warehouse located near the SF airport as a sales office and shipping facility. But never any engineering headquarters and or build shop. ZED built most of their older gear like the amp you have. Autotek and Hifonics were just sales names with NO engineering or internal technical back bone, Just a sales group and a name.. nothing more...Sorta like they are today...
ZED audio might have replacement pots < big maybe but they also used these same pots on most of all the older Hifonics amps also. just not the same value.>
On the right you will see three brand new replacement pots sold to me by Autotek four years ago for $18.00 each + shipping. I actually bought 5 and used two in a guys amp so it would all be like new....Hence my spare exact USED pot left over.
I wish you luck on finding cheap replacements, the rear body size is the issue and the notch located up front to align the pot to the case and lock it in so it does not twist with knob spin. Other then that the value of 20K ohm dual gang pot is the generic info required.
Are mine for sale ? Sorry, no I have scruples and I kept these so I could maintain fast turn around even if it cost me out the back end like these did.....
Crackling noise in left channel. fritz39 Solid State 1 20th January 2009 11:57 PM
K-502 Left Channel is out udailey Tubes / Valves 3 21st March 2008 05:12 PM
Harman Kardon HK6950R left channel problem difflvl Solid State 20 24th September 2006 05:22 AM
Quad 44 preamp no sound in left side jollyrogernl Solid State 8 3rd April 2006 01:35 PM
left channel distortion mic_ael Chip Amps 6 17th February 2006 12:13 AM
Page generated in 0.08528 seconds (73.02% PHP - 26.98% MySQL) with 11 queries
