I worked on this amp awhile back i replaced the power supply section. The amp was working perfect i even showed the customer it was working perfect.
Got the amp back today i dont know what he did but the amp has no output. Its not producing rail voltage. Wondering what to check?? |
#2 |
There is also an op-amp right behind the rca's that is showing voltage for 1 sec then it reads 0 volts on all pins . just wondering where i should start
#3 |
The power supply is probably shutting down due to an over-current or a DC offset fault in the output section. Is there any DC across either of the channels as the amp tries to power up?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
no dc output in either channel upon powering it up when i checked it now the amp goes into protection mode.
#5 |
Does it draw excessive current before going into protect mode?
#6 |
no as soon as i hook remote voltage to it it just goes into proctection wont come out of protection mode
#7 |
Ok i fixed the protection problem in the amp. Now the amp powers up fine.
Still have no output . I checked the 14 pin ic on the driver board for the outputs and have 0volts on all pins. Wondering if anyone knows what ic this is since its been defaced |
#8 |
Can you post a photo of the driver board?
#9 |
Ok heres a pic of the output driver board and the main circuit board of the amp without the driver boards in it
#10 |
I'm not sure what the original IC is but an IR2110 worked in an amp (lightning audio amp) with a similar driver board.
Is the amp producing positive and negative regulated and rail voltage?
| MB Quart tweeters | Coenlaf | Multi-Way | 25 | 18th January 2011 05:36 AM |
| Help with MB Quart Speakers | stax | Multi-Way | 4 | 30th November 2007 03:21 PM |
| FS: Scan-Speak 25W/8562 woofers/MB Quart MBM 50 S Mid-Range/MB Quart MCD 19E Tweeters | Ballylongford | Swap Meet | 0 | 1st August 2006 07:20 AM |
| MB Quart | Slinkylink | Multi-Way | 1 | 14th September 2005 01:56 AM |
| mb quart qsd216 | tenderland | Car Audio | 4 | 31st July 2004 12:31 PM |
| Page generated in 0.10552 seconds (78.06% PHP - 21.94% MySQL) with 11 queries |
