Go Back   Home > Forums > General Interest > Car Audio
Old 9th February 2010, 09:26 PM   #41
at the opamp (393) i have voltage for half a sec then it goes to 0 volts on all pins same with the outputs, The rectifiers are off the board i tested each one and all test fine also tested all power supply fets all test fine.
Checked the voltages on the sg3525ap on the power supply driver board
pin1=0
pin2=5.16
pin3=0.2
pin4=0.24
pin5=2.06
pin6=3.69
pin7=2.04
pin8=4.91
pin9=5.70
pin10=.07
pin11=5.16
pin12=.01
pin13=12.31
pin14=5.14
pin15=12.31
pin16=5.16
i replaced one of the 7812's and still no rail voltage in this amp
wondering what else could it be??
i have voltage on the fets
leg1= 5.15
leg2= 13.08
leg3=0
Wondering what else i should check?
Old 9th February 2010, 09:30 PM   #42
Looking at the center legs of the power supply FETs (check all of them) with your scope, do you have a square wave that swings from ground to 2x the B+ input voltage?
Old 8th March 2010, 06:28 AM   #43
Perry,
I misplaced a transistor for this amp im trying to put it back together.
The transistor is an mpsa13 Can i sub this for something else??
Old 8th March 2010, 06:38 AM   #44
The MPSA12, 13 and 14 are very similar. The MPSA14 is used in some of the SoundStream amps so you may have those. I don't know of any other common transistor that has similar characteristics (high current rating and very high gain).
Old 8th March 2010, 06:41 AM   #45
Ok cool i have a old soundstream board for parts and it has the mpsa14's in it should work right??
Old 8th March 2010, 07:02 AM   #46
Perry,
On my notes on this amp it has fmg22r and fmg33s but not sure if i wrote the 33s down wrong.
would the 22s's work also? with the fmg22r's
Old 8th March 2010, 07:22 AM   #47
I don't know how the MPSA13 is being used but in most circuits, the MPSA14 should be interchangeable.
The 33 is in a larger case. The S version is the positive rectifier. The R version is the negative rectifier so the S and R are not interchangeable.
MB Quart tweeters Coenlaf Multi-Way 25 18th January 2011 05:36 AM
Help with MB Quart Speakers stax Multi-Way 4 30th November 2007 03:21 PM
FS: Scan-Speak 25W/8562 woofers/MB Quart MBM 50 S Mid-Range/MB Quart MCD 19E Tweeters Ballylongford Swap Meet 0 1st August 2006 07:20 AM
MB Quart Slinkylink Multi-Way 1 14th September 2005 01:56 AM
mb quart qsd216 tenderland Car Audio 4 31st July 2004 12:31 PM
Page generated in 0.08739 seconds (75.14% PHP - 24.86% MySQL) with 11 queries
