Go Back   Home > Forums > General Interest > Car Audio
Old 9th February 2010, 01:31 AM   #31
On the rectifiers i have 0.63 on legs 1 and 3 middle leg 0 volts
I should have my scope back this week its fixed all i need to do is buy some new probes.
My friend said hes comming over this week to set up my work stationn
So i have a sine wave generator, my scope, a amperge meter and all the good stuff So i should be back in business shortly
Old 9th February 2010, 02:09 AM   #32
Did you try placing the black probe on all of the points suggested?
Old 9th February 2010, 02:48 AM   #33
yes on the center tap on the rca shield and on chasis ground still same readings
My friend testes the power supply in the amp and its working perfectly he said.
So the problem is in the output side somewhere
Old 9th February 2010, 04:20 AM   #34
What was the criteria used to determine that the power supply was working properly?
It's not producing any rail voltage.
Old 9th February 2010, 05:36 AM   #35
we had the outputs out of the amp. And tested positive and negative rails, also tested the gates with my scope nice square waves on the gates and the rails both deflected the same
Old 9th February 2010, 10:32 AM   #36
Why are you getting ~0v of rail when you measure with your meter?
Old 9th February 2010, 04:13 PM   #37
i dont understand this amp i get 0 volts of rail on outputs. Then i pulled the op-amp (kia393) and i got voltages at the outputs not what i need there but got like 7 volts to stay there so i replaced the kia393 with a lm393. Same thing 0 volts at outputs
Old 9th February 2010, 08:26 PM   #38
Post the voltages on the 393 and the 494.
494
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
393
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Old 9th February 2010, 08:45 PM   #39
It wont let me get the voltages off the 393
im gonna do somemore checking into the power supply of this amp and see what could be causing the no rail voltage issue.
Will it produce rail voltage without the driver board for the outputs in the amp?
Old 9th February 2010, 08:50 PM   #40
Having the output driver board out of the amp shouldn't cause the power supply to shut down.
What do you mean it won't let you measure the voltage on the 393?
MB Quart tweeters Coenlaf Multi-Way 25 18th January 2011 05:36 AM
Help with MB Quart Speakers stax Multi-Way 4 30th November 2007 03:21 PM
FS: Scan-Speak 25W/8562 woofers/MB Quart MBM 50 S Mid-Range/MB Quart MCD 19E Tweeters Ballylongford Swap Meet 0 1st August 2006 07:20 AM
MB Quart Slinkylink Multi-Way 1 14th September 2005 01:56 AM
mb quart qsd216 tenderland Car Audio 4 31st July 2004 12:31 PM
Page generated in 0.10515 seconds (74.97% PHP - 25.03% MySQL) with 11 queries
