Go Back   Home > Forums > General Interest > Car Audio
Old 7th February 2010, 11:43 PM   #21
never got it to produce rail voltage yet
Old 8th February 2010, 03:45 AM   #22
That would be the first thing you need to do. Does it go into protect with the audio driver board out of the amp?
Old 8th February 2010, 11:22 AM   #23
it doesnt go into prtection at all with the audio board in or out of the amp.
Thye 7812 is connected to the 0.1 pico farad caps then goes to the driver board.
Can i raplace the resistor looking caps with any 0.1 pico farad cap since i accidently broke the lead off one of them?
Old 8th February 2010, 01:09 PM   #24
0.1uF, not pF.
Virtually any type would work. The original was likely a ceramic capacitor. A mylar/film capacitor would also be OK.
Post the voltages on the power supply IC.
IC#
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Old 8th February 2010, 08:47 PM   #25
They are using a Sg3525ap on the power supply driver board
pin1=0
pin2=5.16
pin3=0.2
pin4=0.24
pin5=2.06
pin6=3.69
pin7=2.04
pin8=4.91
pin9=5.70
pin10=.07
pin11=5.17
pin12=.01
pin13=12.31
pin14=5.14
pin15=12.31
pin16=5.16
Old 8th February 2010, 08:51 PM   #26
If it doesn't have rail voltage, the power supply FETs have failed or the rectifiers have failed.
Do you have 5, 12 and 0v (G, D, S) on each of the power supply FETs?
Old 8th February 2010, 09:32 PM   #27
leg 1= 5.15
leg2= 13.08
leg3=0
on all of the power supply fets
7812 reads
leg1= -39.34
leg2=0
leg3=0
Old 8th February 2010, 09:43 PM   #28
What do you have on the 3 legs of the rectifiers? Place the black meter probe on the center tap of the power transformers, on the RCA shield and on the chassis ground if you don't initially see any rail voltage.
The 7812 is generally only rated for 35v. It may have gone into protection. Can you lower the 12v power supply voltage so the voltage feeding it drops to 35v to see if it will produce output?
If it doesn't, pull leg 3 and insert a low value resistor (1 ohm - 5 ohms) to see if it will produce output. Measure the voltage across the resistor to determine if it's producing any current.
Old 8th February 2010, 10:48 PM   #29
Which one are the rectifiers in this amp i have one that says d600k
And some fmg part numbers
Old 8th February 2010, 10:59 PM   #30
FMG are typically rectifiers. The D600K is likely an NPN transistor.
MB Quart tweeters Coenlaf Multi-Way 25 18th January 2011 05:36 AM
Help with MB Quart Speakers stax Multi-Way 4 30th November 2007 03:21 PM
FS: Scan-Speak 25W/8562 woofers/MB Quart MBM 50 S Mid-Range/MB Quart MCD 19E Tweeters Ballylongford Swap Meet 0 1st August 2006 07:20 AM
MB Quart Slinkylink Multi-Way 1 14th September 2005 01:56 AM
mb quart qsd216 tenderland Car Audio 4 31st July 2004 12:31 PM
Page generated in 0.09848 seconds (76.51% PHP - 23.49% MySQL) with 11 queries
