Go Back   Home > Forums > General Interest > Car Audio
Old 1st February 2010, 05:20 PM   #1
Default Rockford Fosgate 451s
Wondering if the irfz44's will work in this amp ?
Old 1st February 2010, 06:18 PM   #2
What were the original parts?
Old 1st February 2010, 07:13 PM   #3
MTP50n06v
Old 1st February 2010, 07:36 PM   #4
The Z44s should be OK.
Old 1st February 2010, 07:39 PM   #5
Ok cool got the amp up and running perfect.
Not to switch amps on you but i have a 360.2 . All fets test fine drivers test fine and gate resistors test fine. The 337 and 317 were off the board tryed powering it up and it draws excessive current like crazy wondering what might cause this?
Old 1st February 2010, 08:02 PM   #6
Set the bias pots fully counter-clockwise to see if that helps.
Why were the regulators pulled?
Old 1st February 2010, 10:01 PM   #7
i didnt open the amp up before i tested it by powering it up with a current limiting resistor cause i was told the the amp worked.
I set the bias pots all the way down still draws current
Old 1st February 2010, 10:05 PM   #8
Power it up through the current limiting resistor and measure the DC voltage across each of the source resistors. If you find that one channel has one or more source resistors that have more than 0.000v DC across them, that's the channel that needs to be repaired.
Old 22nd October 2011, 04:37 PM   #9
Default 451S will not power on
I've been running two RF 451S (awesome!) amps for years on a couple of Pioneer XMPP's bridged down @ 8 ohms each amp/woofer with reversed polarity.
They sounded great, and the amps ran cool for hours, but the woofers would clip easily at low frequencies.
So, I tried upgrading to a pair of Aura 12.4s, and this is what happened:
1 amp/woofer powered right up and sounded GREAT! No distortion at low frequencies and pretty much exceeded the SPL of two XMPPs.
1 amp/woofer sound like bvvvvt - bvvvvvt - bvvvvt, so I immediately ran to my front seat and and powered off the stereo.
Upon inspection, it seems like I was sent a faulty woofer. When I gently push the cone in and out, I hear a loud scratchy noise.
Now, the amplifier that was connected to this faulty woofer will not power on.
I'm not much of an electronics troubleshooting guy, I do computer networking for a living - but one of my co-workers is very good with electronics.
Does anyone here have any idea what could have possibly happened?
What questions should I ask him, or even have him look at?
With the speaker disconnected it will not power on, nothing, nada.
HELLPPP!!
These amps are like irreplaceable, and I've treasured the both of them and treated them with nothing but care for their entire lives!
- Justin
Old 22nd October 2011, 10:12 PM   #10
The amp could have failed and damaged the woofer. The woofer could have failed and caused the amp to fail. You could have has a defective woofer.
Disconnect the woofer from the amp, confirm that the fuse is intact and see if it will power up. If it does, measure the DC voltage across the speaker terminals to confirm that it's well under 1v before connecting another woofer to it.
If you need further help, copy and paste posts #9 and 10 into a new thread and I'll try to help. I won't answer any more questions here.
Rockford fosgate amp mike49504 Car Audio 16 25th April 2010 09:30 PM
rockford fosgate p4004 mike49504 Car Audio 17 28th January 2010 07:27 PM
repair of rockford fosgate power 451s chemid51 Car Audio 10 26th December 2009 08:34 AM
Rockford fosgate 800a2 fongman Car Audio 39 28th February 2009 08:35 AM
Bias Rockford Fosgate Hi Speed Car Audio 2 19th May 2008 08:37 PM
Page generated in 0.09780 seconds (76.86% PHP - 23.14% MySQL) with 10 queries
