hello i am new to this forum, i have a simple question.
I have a Denon dca800 amplifier and i need to replace the power mosfets in one of the channels, they say j174 and k1296 on them. are these the same as 2sj174 and 2sk1296? Where is the best place to buy them?
Many thanks in advance,
You are likely correct if the parts look like the ones in the following datasheets:
http://datasheet.octopart.com/2SJ174-Hitachi-datasheet-104478.pdf
http://datasheet.octopart.com/2SK1296-Hitachi-datasheet-104372.pdf
The following search engine will give you US based distributors. B&D has both in stock.
Octopart - Electronic Parts, Electronic Components, Datasheets
You may also want to try posting a request for EU distributors on the 'parts' or 'solid state' forums.
thank you for the fast reply. I have found a place that i have used before they have the 2sj174 but the 2sk1296 they surgest http://www.datasheetcatalog.org/datasheet/vishay/70291.pdf does this look right to you?
many thanks in advance
Is there any information on this amplifer? It is new to me i found it at the dump.
