Kicker KX1200.1 Class D blown
Old 31st January 2010, 07:03 PM   #1
mbates14 is offline mbates14
Default Kicker KX1200.1 Class D blown
Just ran into one of these, it has U508 burned and blown, along with R333, R233, and R559.
Someone has been into this thing before, all the outputs have been replaced by someone else along with the 2 drivers and a few more resistors.
They forgot to do these parts i guess.
Here is the problem. the resistors are burnt beyond recognition so i cant figure out what the values are.
Also the U508 are one of the ICs with the scratched off numbers, but the IC is fried and blown. Does anyone know what this IC is?
Old 31st January 2010, 07:11 PM   #2
Perry Babin is offline Perry Babin  United States
R559 = 1k
R333 = 180
R233 = 180
U508 = LM361
Old 31st January 2010, 07:16 PM   #3
ok. I just found R323 blown. what is it?
Old 31st January 2010, 07:20 PM   #4
Also need R303, R223, R203 along with R323 as requested.
Old 31st January 2010, 07:24 PM   #5
223, 323 = 120 ohm 1%
203, 303 = 220 ohm 1%
Old 2nd February 2010, 03:37 AM   #6
k. parts are on order, hopefully she will be an easy fix... anything i should watch out for?
Old 2nd February 2010, 07:30 AM   #7
While the LM361 is out of the circuit and after replacing all known defective components, connect a jumper between the two points indicated on the attached photo. When you power the amp up, there should be absolutely no DC on the center legs of the outputs.
Old 2nd February 2010, 06:51 PM   #8
the amp came onwith defective components before, just no audio.
Old 3rd February 2010, 12:30 PM   #9
perry i sent you a PM...
Old 5th February 2010, 04:00 AM   #10
Changed those parts and shes boomin again....
Kicker KX1200.1 Class D blownHide this!Advertise here!
Need a little help fixing a kx1200.1 Pics Inside wccoug21 Car Audio 10 5th October 2011 03:32 PM
Repairing Class A/AB amp with Blown Fuse excetara2 Analog Line Level 5 8th March 2009 09:34 AM
I need help with blown kicker ZR240! chipper Car Audio 5 13th February 2009 09:14 PM
Kicker SX650.1 help shagone Car Audio 12 19th March 2008 07:35 AM
Kicker Amps skooter Car Audio 3 8th November 2007 03:53 AM
Copyright ©1999-2017 diyAudio
