I decided to experiment and try the kicker shallow 6.5" subs. They handle 150watts rms and seem to have enough cone area to create good mid bass and I'm sure with enough clean power going to them I can force them to produce upper mids as well. I will have them in the front doors and the rear deck free air. What I'm trying to decide is whether to run 4 or 2 ohm version. I'm running two ppi a600.2 amps in stereo mode. What I'm wondering is if running the 2ohm version will change the damping factor of the amps enough to modify the frequency response characteristics of the woofers enough for me to notice... as in a negative way. I ran my old a600 at 4ohm mono liquid cooled and the power output increased tremendously and seemed to maintain a flat response, at least when running subs. Any recommendations or things to worry about besides overpowering the subs?
Don't worry... you can always turn the gain down! |
#2 |
I ordered the 2ohm version today, maybe that will give a little more headroom. I'll post back on this in a week or two (when I get the car back together)
#3 |
Well although I don't have my car back together I did recieve the cvt 6.5 subs and they appear to be too large to fit in the doors. They are a little deeper than my components and the basket will require a larger hole. Fitting them in the rear deck would be no problem but since I plan on getting another car to transfer my drivetrain into, I won't be able to check the front door fitment for quite a while. I should have waited to order the subs because I found out a few days back that my car is twisted pretty badly and I'll have to find another body.
| How eliable ar Kicker L5 subs. | skooter | Car Audio | 0 | 7th October 2008 10:39 PM |
| When are the MTX shallow subs coming out?!?!? | ppia600 | Car Audio | 0 | 22nd December 2007 03:10 AM |
| Need Opinion on Kicker Subs | that1guy3689 | Subwoofers | 0 | 19th July 2005 10:32 AM |
| Shallow mount 4 ohm 6.5"? | MITMechE | Multi-Way | 1 | 7th February 2005 08:02 AM |
| 6" Subs to Mids? | LqDFx | Car Audio | 5 | 14th July 2004 03:43 AM |
| Page generated in 0.07964 seconds (74.18% PHP - 25.82% MySQL) with 10 queries |
