Go Back   Home > Forums > General Interest > Car Audio
Old 29th January 2010, 07:34 PM   #1
Default RF 250M or 200M schematic
Looking for the 250M or 200M schematic. I was told it was a 301S, I now know it is one of these two. A few sm resistors are missing and would like the values before I continue.
Thanks,
Cory
Old 29th January 2010, 07:44 PM   #2
I have 2 schematics that have the file names 200m and 250m but the text has them as H200a1 and H150a1. The PC numbers are 2031 and 2034. The pc number of the 301s is a 4308.
Email me if you want the schematic diagrams.
babin_perry@yahoo.com
Old 29th January 2010, 07:56 PM   #3
The board reads PC-4309-H. No camera right now so I can't post a pic. It has a single TL072 opamp stage with 2 rca's feeding it. Both the power and output terminals are offset to one side.
cory
Old 29th January 2010, 08:06 PM   #4
Check your email.
Old 29th January 2010, 08:11 PM   #5
Thanks, that seems to be it.
The power supply shows 50n06, which essentially is irfz44. My board hads irf3205's. The gate resistors are 33ohms, any thoughts.
Old 29th January 2010, 08:20 PM   #6
Any of those will work in this amp. I'd likely use Z44s in it.
Old 29th January 2010, 09:24 PM   #7
I dropped in a IXYS 90N055, which is pretty close to the 3205's. The supply fired up and I have 38V rails.
Now I need to replace the missing resistors and RV101. I have a 10K version of RV101, should I then double the two other resistors in the feedback to keep things proportional?
Old 29th January 2010, 09:31 PM   #8
You only need to scale the other resistors in the gain circuit if you don't want the gain to be more than it would normally be.
Old 30th January 2010, 08:42 PM   #9
What causes C129 to burn up? It's tied to the output terminal. I did read the value of R187 wrong I think. I had 25ohms in there, then read the schematic better and seen it is 2.7ohm. I now have 4/10.7ohms in parallel. Maybe it was messed up from the previous resistor value.
I have a nice waveform until that parts goes.
Old 30th January 2010, 10:04 PM   #10
Apparently I caused damage to the cap with my resistor issue. I have since replaced the cap and all is good.
Thanks again for all the help.
Marantz 250M Repair PB2 Solid State 49 11th January 2012 05:09 AM
~AC~ easy line/RF filter + surge supressor schematic wanted bluesmoke Everything Else 2 9th May 2011 06:06 AM
RF 500a2 schematic brandes.cm Car Audio 1 8th January 2010 07:54 PM
yamaha NS-200M mack2 Multi-Way 8 27th April 2007 05:37 AM
Does anybody have schematic of RF Punch 250.1? valterdaw Car Audio 10 12th September 2006 04:32 PM
Page generated in 0.09933 seconds (76.44% PHP - 23.56% MySQL) with 10 queries
