Hey everyone!
I have a APVB-120B loaded enclosure and i am about to buy an amp for it... Here's the details on the enclosure: 2 2ohm subs, SVC, 750 watts rms(total), 1500 peak, 102 db sensitivity, 28-150 Hz range, Could someone please tell me which of these two amps will do the job? Power Acoustik LFA2-1800 (lfa21800) 2-Channel Amps Car Amplifiers Car Audio Car Audio, Video, & GPS Navigation - Sonic Electronix Or Power Acoustik LFA2-2200 (lfa22200) 2-Channel Amps Car Amplifiers Car Audio Car Audio, Video, & GPS Navigation - Sonic Electronix I dont want to spend a lot (As you can see from the brand of subs and amp i chose lol) but i'm afraid the first amp i listed wont cut it. Thanks in advance ~Skylar |
#2 |
it is recomanded to buy a class d amp, because what you chosed is in AB class, with less distorsions but it consume more. And another aspect is that those amps can't have those powers on the output. in the descriptions they say that it has 3x25A=75A, at 14.4V 1080W, but the fuses are 20% over rated from the real cosume, and i don't know that in this world somebody release an amp with 100% efficiency...
think twice before buy an amp! succes sorry for my english |
#3 |
Your English is better than a LOT of the people that live here.
If it ain't broke Don't fix it |
#4 |
Those amps won't do anywhere near rated power
what is your budget? this would work DSC1500.1D - MB Quart Monoblock 1500 Watt Discus Series Class D Amplifier |
#5 |
![]() That was the most i can spend... maybe 15 bucks more at the most. so the second amp wont work? I seriously cant wait any longer, gotta have some bass! |
#6 |
"PWM (Pulse Width Modulated) MOSFET power supply and transistor outputs" (first amp)
actually is class D. unless they mean that only the power supply is PWM. but then you could still get some power because the voltage can be stepped up. |
#7 |
well i bought the 2 ch 2200 watt amp along with a sony cdx gt340.
Class D amps are ok but why would i want a 1 ohm setup, that makes the subs sound like poop |
#8 |
There shouldn't be any audible difference at any given impedance that's within the amplifier's rated impedance range (assuming that the amplifier is in good working order).
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#9 | |
RMS Power (4 ohms) 370 watts x 2 channels RMS Power (2 ohms) 450 watts x 2 channels RMS Power (1 ohm) N/A Bridged RMS Power 900 watts x 1 channel Fuse Rating 25A x 3 Power Acoustik LFA2-1800 RMS Power (4 ohms) 300 watts x 2 channels RMS Power (2 ohms) 380 watts x 2 channels RMS Power (1 ohm) N/A Bridged RMS Power 760 watts x 1 channel Fuse Rating 30A x 2 |
#10 |
My installation turned out great!
I will post a bunch of pics in the next few days! I cant believe how well this setup turned out, these were cheap subs and amp! $245 for both on ebay |
| Colpits clock vs aftermarket clocks | tubenut | Digital Source | 0 | 17th February 2005 10:30 AM |
| Aftermarket head, stock amp | Thorshavn | Car Audio | 6 | 10th June 2004 02:24 AM |
| Aftermarket indash CD skips to bass | eRiCdWoNg | Car Audio | 5 | 8th May 2004 03:59 AM |
| Car audio project | Larr_e_boy | Multi-Way | 4 | 30th May 2001 01:23 AM |
| Page generated in 0.09524 seconds (86.28% PHP - 13.72% MySQL) with 10 queries |
