Yeah I just bought one from eBay used stating it didn't work so I kind of was expecting something wrong. What FETs could I use for a sub? I would like to get this to work because it looks like it would put out some power. One of the power supply fets is toasted pretty bad but the others look okay. But I know those are shoot out.
Feel the PUNCH |
#2 |
I'd suggest using IRFZ44s.
Don't forget to check the gate resistors and the driver transistors.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
can you post a photo of where I can on a 225? I also need another torch to remove the fets. Where can I get that from? What type of solder do I use?
Feel the PUNCH |
#4 |
Read the following post (#29). It tells how to replace transistors on a similar insulator strip.
t30001bd schematics The gate resistors are R19, R20, R36 and R46. The driver transistors are Q1, Q2, Q4 and Q5. It may be easier (instead of checking the transistors) to simply measure the voltage on the gate pads (solder pad for leg 1 of the FETs) of the FETs (after confirming that the gate resistors are within tolerance - ±5% of marked value). Use standard solder.
#5 | |
I'm also curious do I get four irfz44's? And do i check it power to the amp and rem voltage applied?
Feel the PUNCH |
#6 |
Yes. Four Z44s.
Yes. With B+ and remote voltage applied (although B+ voltage isn't necessary on this amp).
#7 |
I measured 36.4 ohms for the gate resistors is that correct?
Feel the PUNCH |
#8 |
What are the numbers printed on the resistors?
If you haven't done so, cut the first leg of the blown power supply FETs so that they can't skew the readings.
#9 |
I torched them out of the mesha strip now how would I be able to resolder them back on? What if I tin the mesha strip with some solder?
Feel the PUNCH |
#10 |
Oh yeah can you please send me a link to where I can find the irfz44s?
Feel the PUNCH |
| precision power A800/2 (blown transistors) | anwaypasible | Car Audio | 3 | 26th November 2009 01:35 AM |
| Orion HCCA 225 power supply | hipcatrob | Car Audio | 5 | 25th April 2008 01:48 PM |
| Blown power supply caps | big russ | Chip Amps | 10 | 11th May 2007 05:43 PM |
| Page generated in 0.10748 seconds (79.48% PHP - 20.52% MySQL) with 10 queries |
