diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Power acoustik schematic (http://www.diyaudio.com/forums/car-audio/159051-power-acoustik-schematic.html)
brandes.cm 19th January 2010 11:54 PM
I have a BAMF1600/4 series that I would like a schematic for. I sent off an email to Power Acoustik and haven't heard anything.
I am more interested in the output config, it uses all irf540's. Not what I am used to seeing. So any schematic with that config would be useful.
Thanks,
cory
Perry Babin 20th January 2010 12:04 AM
The last time I requested a schematic for this series, they wouldn't release it because it was still in production.
Did you misread the part number? In the 2200/2 I repaired, it had IRL540Ns in it.
brandes.cm 20th January 2010 12:22 AM
I did indeed, they are IRL540N. I see the L version is rated at 36 amps rather than 33. Is that the only difference?
Perry Babin 20th January 2010 12:41 AM
No. The L version has a 2v threshold while the standard FET has a 4v threshold.
brandes.cm 20th January 2010 01:12 AM
Hence the datasheet stating "logic level" gate. I will have to hunt down the parts, since a standard 540 doesn't seem to work!!!
Perry Babin 20th January 2010 02:45 AM
I used standard IRF540Ns in the one I repaired and didn't have any problems. Why didn't they work in your amp?
brandes.cm 20th January 2010 01:21 PM
They did work I guess. I just noticed the lower half of the signal being clipped prematurely. Not using the same part made me think it was the replacement parts fault. I need to look a little further into this amp.
Perry Babin 20th January 2010 07:11 PM
The biasing likely needs to be set properly.
brandes.cm 21st January 2010 02:18 AM
2 Attachment(s)
Here is a pic of the board. It has bias test points for all 4 channels, what am I looking for on those. Right now they all read differently. When I adjust the bias pot for channel one, it will pop a 10 amp fuse when adjusting in either direction. With Rockford amps I just put a voltmeter across my .005ohm series resistor in my supply line and watch for the mV's to shoot up, then adjust back a little. I don't see that spike with this amp.
When I load channel 1 with 3 ohms I lose the lower half of the sine wave. Unloaded I can get ~22Vrms out, normal channel is 24.5Vrms.
cory
mbates14 21st January 2010 02:27 AM
almost like one of the transistors isnt conducting at all? look at the drivers and double-make-sure
Resources saved on this page: MySQL 18.75%
