Power acoustik schematic
Old 21st January 2010, 09:02 AM   #11
Perry Babin is offline Perry Babin  United States
The source resistors appear to be intact but if one is well out of tolerance, that could cause the amp to clip early.
Is the defective channel the only one that causes an increase in idle current when the bias pot is turned clockwise or counter-clockwise?
Adjusting the bias by monitoring the idle current worked on the 2200/2 I repaired.
The bias is important on this amp because (if I'm not mistaken), the bias pot controls the current through the differential amplifier and if there is insufficient current through the differential amp, the following stages can't be driven properly.
In addition to checking all of the driver transistors, check the SMD resistors for that channel on the driver board.
Old 21st January 2010, 12:15 PM   #12
brandes.cm is offline brandes.cm  United States
By adjusting the bias pot I was able to get the channel to match the others. I will play music through it all day to see if my adjustments have any bad effects.
Power acoustik schematicHide this!Advertise here!
Power Acoustik Amp Help 22chet Car Audio 7 22nd February 2009 11:05 AM
Power Acoustik Amp chadrock Car Audio 28 19th March 2008 06:37 AM
Power Acoustik A2400db spooney Car Audio 21 19th March 2008 01:05 AM
Help me to fix POWER ACOUSTIK please! Mordor Car Audio 10 13th February 2006 08:58 AM
1400 watt power acoustik 88civic Solid State 5 27th July 2002 10:08 PM
