The problem is when the amp turns on, the music will crackle/hiss for about 1/2 second before it sounds like normal, then it sounds great. Now Ive heard of turn on thump but never this. Have you heard of this before? What do you think it might be? Thanks for any help.
BTW, I confirmed this issue in the house by using a power supply and ipod. I opened up the amp to inspect and found this: ![]() ![]() So what purpose do these caps serve so close to the speaker output? Could this be causing the issue? |
#2 |
Those are not the cause of your noise.
If it ain't broke Don't fix it |
#3 |
#4 | |
I agree these are most likely not the source of your noise issue but they may be a symptom of your noise issue < a by-product caused by the noise issue > Once you find the noise issue I would replace these just for good measure... I would start looking for bad solder joints and bad switches first. After that I would be looking into the muting circuitry and other more advanced issues. Freeze spray can be helpful in detecting bad solder and contact cleaner for the switches and pots.. Last edited by 1moreamp; 18th January 2010 at 12:36 AM. Reason: addendum |
#5 |
sounds to me the amplifier is oscillating parasitically, bringing the zobel filters into a short circuit thus killing your caps.
#6 |
I had the amp completely apart and didnt notice any bad solder joints, all though I did touch on some that looked a little funny.
| Diamond Audio D6 1500.1 diagram | clayton | Car Audio | 10 | 14th May 2012 01:46 PM |
| Infinity Kappa Perfect vs. Diamond D6 | chcc5th | Car Audio | 1 | 7th May 2007 05:14 PM |
| Diamond Audio D6 1500.1 manual? | mbayaq579 | Car Audio | 2 | 8th March 2007 07:30 AM |
| Wierd Car Audio Issue | nevadaspierce | Car Audio | 3 | 11th November 2006 03:31 PM |
| How can I reduce mechanical turn on and turn off noise? | soundNERD | Chip Amps | 8 | 28th October 2003 01:43 AM |
| Page generated in 0.07506 seconds (84.11% PHP - 15.89% MySQL) with 10 queries |
