Go Back   Home > Forums > General Interest > Car Audio
Old 17th January 2010, 05:23 AM   #1
Default Mtx 6500d
I got this amp in to repair. THe amp powers up but no output. Its not producing rail voltage. I checked the voltage at thr rectifiers and very low voltage.
I then checked the tl494 and the voltages read
1=2.37
2=2.37
3=3.53
4=1.13
5=1.48
6=3.29
7=0
8=13.33
9=0
10=0
11=13.33
12=13.33
13=4.90
14=4.90
15=4.90
16=0
Wondering whats the next step to get this amp working
Old 17th January 2010, 05:32 AM   #2
I think that pins 1 and 2 are for the regulator and it appears that the rail voltage is precisely what it should be. Precisely what is the DC voltage on the center legs of the rectifiers?
Place the black meter probe on the amplifier's ground terminal.
Old 17th January 2010, 06:24 AM   #3
meter does nothing 0 volts and -0 volts on center leg of both rectifiers black probe on amps ground
Old 17th January 2010, 06:38 AM   #4
Are you sure the meter is on DC volts?
Look at the attached image. It shows how the rails are connected to the voltage dividers. Unless the IC is shorted internally causing the two terminals to have precisely the same voltage, the amp has to be producing rail voltage. The voltages in the second image are from a 6500D in good working order. You can see that the voltages are almost identical to yours.
Old 17th January 2010, 06:45 AM   #5
Im 100% positive the meter is set to dc volts if i put red probe on amps positive terminal and black on ground terminal i get 13.89 volts
black probe on amps ground terminal red probe on fep1620ct's middle leg =0 volts
black prob on ground terminal red probe on fen1620ct's middle leg -0 volts
Old 17th January 2010, 06:46 AM   #6
What do you get if you put the meter on AC volts and touch it to the outer legs of the rectifiers?
Old 17th January 2010, 06:48 AM   #7
Ok pulled the board out re did some solder connections
Fep1620 = 59.6 volts on center leg
Fen1620 = -59.2 volts on center legs
But amp has no output
Old 17th January 2010, 06:56 AM   #8
OK. Regulated voltage on ALL op-amps?
Gain at max?
Old 17th January 2010, 07:13 AM   #9
im getting similar readings on all op amps besides 1 and that reads
1=0
2=0
3=0
4= -17.80
5=0
6=0
7=0
8=17.85
This op and is located behind the push switch by the gains
Old 17th January 2010, 07:26 AM   #10
How is this one different from the others?
Did you check the gain to make sure it was not at 0 gain?
MTX 6500D - No Output Pioneer621 Car Audio 109 25th May 2011 09:35 PM
MTX 6500D Schematic? copekyle Car Audio 7 8th October 2009 09:35 PM
MTX 6500D with problems copekyle Class D 0 17th September 2009 06:36 PM
MTX 6500D repair bil Car Audio 3 29th May 2006 07:19 AM
Page generated in 0.09627 seconds (78.02% PHP - 21.98% MySQL) with 11 queries
