Go Back   Home > Forums > General Interest > Car Audio
Old 5th May 2010, 01:20 PM   #11
I pulled the drivers still reads shorted from pads 1 to 3 on the outputs. Is this normal on this amp or do i have a problem somewhere else?
Old 5th May 2010, 03:45 PM   #12
It's not normal. Have you cleaned the board and examined it to see if there are any solder bridges?
Old 5th May 2010, 05:19 PM   #13
yes cleaned the board no solder bridges anywhere. But reading shorted from pads 1 to 3 on the outputs still
Old 5th May 2010, 05:49 PM   #14
Pull the outputs and check them out of the circuit.
Old 5th May 2010, 07:10 PM   #15
All of the outputs and drivers for the outputs are pulled out of the board. Its still reading shorted from legs 1 to 3 on the pads on the board I found 2 shorted outputs out of the board but still have the same problem without any outputs or drivers in the board still reads shorted between pads 1 and 3
Old 5th May 2010, 07:19 PM   #16
You'll have to track it down by removing components to see when the short is lost then determine what was causing it. Is there anything connected to the base pad except the driver transistor and the base pads of the other parallel outputs?
PPI amp mike49504 Car Audio 12 20th December 2009 10:49 PM
old ppi connectors damage Car Audio 7 17th January 2009 12:45 PM
PPI ART Series a404 "v" PPI Powerclass pc450 swap chemhaz Car Audio 2 21st November 2008 02:23 PM
Ppi Pc4100? dangus Car Audio 5 12th April 2008 06:44 AM
ppi pc1400.2 sc1984 Car Audio 7 2nd October 2007 05:31 AM
Page generated in 0.08009 seconds (73.72% PHP - 26.28% MySQL) with 10 queries
