rockford fosgate p4004 - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 28th January 2010, 02:08 AM   #11
When you replaced the outputs, did you damage, displace or remove the bias transistor?
Is it possible that there is a bad connection on the 3-terminal connector where it solders to the output transistor's insulator?
Old 28th January 2010, 02:52 AM   #12
Maybe.
I can check it and resolder it to make sure its no a bad solder connection
Old 28th January 2010, 05:12 AM   #13
ok it had a bad transistor on the output board i replaced that and amp power up fine. Now i found that it has a bad fain pot in it so i gotta see if i have a 20k pot somewhere
Old 28th January 2010, 05:57 AM   #14
PacParts should stock the OEM pot.
Old 28th January 2010, 06:10 AM   #15
Originally Posted by mike49504 View Post
ok it had a bad transistor on the output board i replaced that and amp powers up fine. Now i found that it has a bad gain pot in it so i gotta see if i have a 20k pot somewhere
Old 28th January 2010, 01:37 PM   #16
This amp is telling me its in proctection. BUt amp powers up fine and plays music fine. Wondering what this might be caused by
Old 28th January 2010, 07:25 PM   #17
When you remove remote voltage, does the power supply shut down like it should?
Old 28th January 2010, 08:27 PM   #18
Ok I just got done with this amp. It was the plug in the amp had a bad solder connection on it. Also had to replace both gain pots both were bad amp sounds really nice and clean
rockford fosgate p4004 mike49504 Car Audio 3 7th December 2009 10:30 PM
Rockford Fosgate T20001bd Triden312 Class D 3 22nd November 2009 11:54 PM
Rockford P4004 Terminal blocks brandes.cm Car Audio 6 15th November 2009 05:35 AM
About rockford fosgate 1500bd RICKY01AGUAS Car Audio 19 28th June 2009 01:28 AM
Copyright 1999-2017 diyAudio
