Repair Help on Orion 2500d
Old 11th January 2010, 12:19 AM   #21
Perry Babin is offline Perry Babin  United States
Did you pull the rectifiers away from the sink to see if any had broken legs? They sometimes break inside the body of the rectifier so you have to push tnel to the side to make sure they're not broken.
The reason I ask is that there's definitely output from the transformer but there's no DC. You should read ~+50v DC on the center legs of the 600 series rectifiers and ~-50v on the outer legs of the 700 series rectifiers. I have one here and powered it up to confirm that that's what you should read.
Old 11th January 2010, 12:59 AM   #22
wccoug21 is offline wccoug21  United States
Yea, I did. They feel pretty solid
Not sure how the rectifier series system works, but they are mur3040pt if that helps.
Old 11th January 2010, 02:02 AM   #23
Do you read ~0 ohms between the RCA shields and the secondary center taps of the power transformers?
If you do, I think you need to pull them and check them thoroughly. It's unlikely that they're open if the legs aren't broken but there seems to be an open/broken connection somewhere.
Old 11th January 2010, 02:46 AM   #24
Yea it does read near 0 ohms... So i should remove the rectifiers and check them?
Old 11th January 2010, 02:52 AM   #25
Yes. Make sure they read ~0.4v (on diode check) with the black probe on the center leg and the red on the outer legs. With the probes reversed, they should read OL (or whatever your meter reads with open leads). Do this for all four.
While you have it out of the sink, look for open/burned traces.
Old 12th January 2010, 04:37 AM   #26
The rectifiers are good, but I found one thing on the board that doesnt look right. I wanted to see what you think about it so it is circled in the pic below
Old 12th January 2010, 07:30 AM   #27
I don't think it's significant (from what I can see in the photo).
Is there something wrong with the solder connection that's closest to the bottom/left of the photo on the transformer winding?
Old 13th January 2010, 02:55 AM   #28
Well what i noticed almost looks like an unused piece of solder which is bridging two traces together. I also compared the board to the pics that you have in your tutorial and I'm pretty sure it is not in your pics.
Not sure exactly where you are talking about, but I haven't noticed anything significant.
Old 13th January 2010, 03:25 AM   #29
That immediate area except for the two resistor leads is the same piece of copper. Is the wire touching the two resistor solder connections?
If it's not touching the resistor solder connections, it's not a problem.
When you tested the diodes, did you find ~0.4v (on diode check) across each diode of the rectifier and when you reversed the probes, did it read OL?
Repair Help on Orion 2500dHide this!Advertise here!
Old School Orion 2150 gx.I must repair this amp spooney Car Audio 99 21st August 2010 02:53 PM
Orion 2500D trouble shooting- protect mode Scanlines Car Audio 5 30th July 2008 10:59 PM
Orion 280GX amp repair thegmann Car Audio 11 11th April 2008 05:44 PM
Orion 222 SX repair questions grjr Car Audio 11 22nd December 2007 07:32 AM
