Go Back   Home > Forums > General Interest > Car Audio
Old 7th January 2010, 09:29 AM   #1
Default SMPS for car amp
I have recently finished my first DIY project. A Dual mono chip amp based on the LM3875 chip.
I am now thinking of making another chip amp for my car. The only problem is the supply voltages required are +-26v.
I know you can buy converters to up the car voltage to 240v AC. Would this be adequate for a decent sounding system? or would i be better trying to find a SMPS design to build?
Dan
Old 7th January 2010, 09:44 AM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Depends, if you know-how, then doing your own could be ok
I would never use step up inverter, then power your amps with what ever home setup you have now
I think for you would be best to just buy car amp, the most safe way for you
Old 12th March 2010, 05:34 PM   #3
ıf you using for car amp. aplication , must you my design. I have using and adaption clarion a2200 amp.
regards
TDA2052 60W Anfi devresi ( +PCB ).....
Old 12th March 2010, 07:59 PM   #4
If you want to build an amplifier for your car but don't want to build a power supply, find a budget amplifier (preferably used) with a switching power supply and tap off of that power supply to power the amp you build.
Chinese/Korean built amps are likely the best choice because most have power supplies with floating secondaries. If you use an amp that doesn't have a floating secondary in the power supply, you'll have to build a special noise canceling input stage for your amp.
toroid for car amp smps sss Car Audio 251 11th January 2009 02:55 PM
Car amp smps needed kissendi Car Audio 5 28th January 2008 04:08 AM
StepUp dcdc smps (car amp) gev Power Supplies 3 7th May 2007 05:40 AM
no smps car amp? How about a aleph X DJNUBZ Car Audio 4 29th November 2005 05:32 PM
Page generated in 0.08544 seconds (76.97% PHP - 23.03% MySQL) with 10 queries
