Couple of tough-dog amps - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 8th January 2010, 03:38 AM   #21
Any browser should be able to open it. A large portion of the graphics on the web are flash graphics.
Old 8th January 2010, 03:44 AM   #22
SWF Decompiler, Flash Decompiler, SWF to Flex, SWF To FLA Converter, Recover FLA
cheers
Old 8th January 2010, 03:46 AM   #23
yeap, so are the large majority of drive by download viral attacks as well...... Well anyways, at least i can see whats going on with the schematics.
Its weird how it keeps doing that. what would cause the drop across the emitter resistors to go to .245v? it does this before the protect kicks in. protect kills the SMPS.
Old 8th January 2010, 04:16 AM   #24
It appears that both drivers are driving the outputs on at the same time. That's why I suspect the diodes and the bias transistor.
It's very rare that flash graphics files are used for malware. I use it for all my graphics because there is nothing else comparable.
Old 8th January 2010, 04:37 PM   #25
Yea you do have a point i guess... hehe
Well, im going to pull the diodes and have a check to see if they are leaky. Otherwise, im at a loss
Old 8th January 2010, 05:11 PM   #26
Diodes check fine out of circuit. im at a loss....
The base of QA12 output NPN is pinning around 9.8V at switch-on before kicking into protect. Base of QA11 PNP is at 0.1v
Old 8th January 2010, 06:11 PM   #27
Remove the 4 differential amplifier transistors (QA2, 3, 4 and 5 on the schematic).
Does it have any DC offset?
Does it still draw excessive current?
New to Forum, love 2A3's, built a couple of amps scottswim Introductions 4 24th November 2008 10:24 PM
A couple beginner questions about amps jperkin2 Class D 2 6th May 2008 06:35 PM
a couple amps im biulding XTRMEASURES Car Audio 9 18th July 2006 06:39 PM
cap couple or direct couple class A SE amp? AudioGeek Solid State 7 7th May 2005 07:16 PM
a couple amps. critics / suggestions needed millwood Solid State 2 24th May 2003 02:46 AM
Copyright 1999-2017 diyAudio
