Hello, I have a Infinity REF475a I got for Christmas. I was testing it and discovered one of the channels puts out a really scratchy sound. The music played through the channel is really distorted. What could cause this? When this happens my personal diagnosis is some DC went into the output and partially fried the output transistors. However, I thought this amp had protection from various faults like this. I was quite careful when hooking it up. Thanks for any replies.
#2 |
Have you tried the following?:
Swapping RCAs to determine if the problem is related to the input signal? Swapping speaker wires at the amp's speaker terminals to see if it's a wiring/speaker problem? Moving all controls/switches through their entire range to see if the problem gets better/worse?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Yes sir, I tried all of that. All of the other channels work fine. Tried A different set of cables and a different source and it still does not work properly.
#4 |
Do want to try to repair the amp?
If so, do you have a scope?
#5 |
The amp is still under warranty. I am going to contact the seller to see what he says. I will probably ship the amp back just to learn they will not warranty it for some stupid reason. In which case I will repair it myself. By that time, with all of the shipping cost I could have bought another amp.
I am an electronics engineering student and I have fixed a few amps for classmates of mine. However, I do not own a scope of my own nor do I have access to one at the moment. I am currently reading the links in your signature. I know a guy named Paul Babin who lives in Louisiana. Thanks for your help. |
#6 |
I am going to try to fix the amp myself. However, I cannot seem to find a schematic online. I think some DC from the power supply went into the RCA for the channel that does not work. I am opening the amp right now. What do I need to check for? I do not own a scope, but I do have a multimeter.
#7 |
#8 |
You have mail from Jason-Martin@live.com
#9 |
I finally got some time to disassemble the amplifier.
I took out the transistors for the channel that is not working, and the diode setting on my meter says the following: TIP35C C=503 E=504 TIP36C C=530 E=531 |
#10 |
Do they both read open when you check from collector to emitter?
| Amp trouble - infinity Kappa 202a | silversweden | Car Audio | 48 | 9th February 2011 08:42 PM |
| infinity referance 7541A amp popping | alti117 | Car Audio | 1 | 1st April 2008 02:45 AM |
| How to open an Infinity Kappa 202a amp? | Compman55 | Car Audio | 10 | 22nd July 2006 05:48 AM |
| Pioneer DEH-P8600MP, Infinity Kappa 693.5i, and Infinity Reference 6402cfp, and more | jawglasswell | Swap Meet | 0 | 13th March 2005 07:38 PM |
| chip amp for infinity intermezzo 2.6 | cowanrg | Chip Amps | 12 | 12th May 2003 06:22 PM |
| Page generated in 0.11177 seconds (74.72% PHP - 25.28% MySQL) with 10 queries |
